Page 1176 of 1304 FirstFirst ... 17667610761126116611741175117611771178118612261276 ... LastLast
Results 11,751 to 11,760 of 13033
Thread: What did you do to your G8 today?
  1. #11751
    Beyond Help texn884's Avatar
    Helotes, Texas
    Quote Originally Posted by pokey View Post
    Took the insurance off recently. Yes it has come to that.. sits un-driven. Actually should have done this long ago when i started storing the G8 in the Winter. Left Comprehensive on in case the house would burn down or fall on it. I'll call when it warms up to start the insurance again.
    Burrrr, I grew up in Fond du Lac and moved to Texas in 1985 much warmer here
  2. #11752
    Helotes, Texas
    Changed the oil and filter myself for the first time, pretty easy! I rotated the tires and installed the these for new fog light bulbs, https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 and so much brighter.
  3. Likes MongosG8, Leon McJones liked this post
  4. #11753
    Dec 2015
    Quote Originally Posted by texn884 View Post
    Does ours take the type 1 or type 2 bulb?
    '09 WH G8 GT
    Premium/Sport
    Red/Onyx
    Rotofab CAI
    Cortex 93 tune
    20% tint
    I just wanted one.
  5. #11754
    Helotes, Texas
    I AM NOT SURE BUT THAT LINK will tell you but they are a perfect fit plus they made bulbs for the head lights also
  6. #11755
    Helotes, Texas
    Quote Originally Posted by Markmsf3 View Post
    Just looked it is a type 1
  7. Thanks Markmsf3 thanked for this post
  8. #11756
    Dec 2015
    Just finished changing the differential fluid, changed the engine oil, dropped the trans pan and changed the filter to a wide mouth and put the Camaro pan on and filled it back up with AC Delco transmission fluid. All in all, it was all pretty easy. The plugs in the differential were hard to get off since they have never been off. I made sure I got the fill plug loose before I messed with the drain plug. It would have been bad if I drained it and then couldn't get the fill plug off. The worse part of the transmission service was pumping the fluid back in it. I had to pump it in with all quart bottles and it got pretty tiresome. I rotated the tires while I had it up and did the tpms relearn. I am done for the day.
    '09 WH G8 GT
    Premium/Sport
    Red/Onyx
    Rotofab CAI
    Cortex 93 tune
    20% tint
    I just wanted one.
  9. Likes -Ray-, texn884 liked this post
  10. #11757
    Helotes, Texas
    Let see, today I adjusted the headlight on passenger side was a little low, cut off the splash guards(the things that hang down underneath) to see if that is what is making the scraping noise when I hit a dip in the road!
    fished out the cap that protects the bulb and that fell down so had to undo the fender liner, took right front tire off again to get to that and re torqued the lugs, so no wheel about to fall off, did I say I did that, opps, lmao
    With the Ultra Penzoil the engine seems to be a lot quieter and added the BG MOA
  11. #11758
    Sep 2012
    down the lane
    Hooked the battery up and started it for the first time since the end of September. Backed it out of the shop so i could put the Silverado HD on the lift and do the front brakes.
  12. #11759
    Helotes, Texas
  13. #11760
    Raleigh/Cary, NC
    Curious on your thoughts of the LED's when you get them installed. I hear mixed things on the LED headlight bulbs. Unfortunately I didn't want to spend $900 for factory HID's for my car and I'm looking for something better than crappy halogens.
    2019 Volkswagen GTI Rabbit
    2019 Chevrolet Equinox LT
