Results 1 to 10 of 10
Thread: Stuck at 5.01 Second 0 to 60
    Bothell, WA
    Default Stuck at 5.01 Second 0 to 60
    So, is this about right?
    I've tried several runs over a one week period.
    Weather: cool, cloudy both times, 65 to 70 degrees
    Altitude: 100 to 200 feet above sea level
    Run: Relatively flat +/- 2% grade at the most
    Surface: Pavement, some starts from brake down lane so starting in some marbles, other run in a closed weigh station, pavement appeared clean
    Configuration: Superchips Cortex 91 Octane tune 50% and 75% torque management, rev limiter disabled, 92 Octane in the tank, 10% Ethanol mix (that is all they sell around here now), tank 1/4 to 1/2 full, no knock of any kind, half washer mod, two washers lower with gasket still in place, stock 19" summer rubber at stock pressures, I'm 6'1" about 220 pounds
    Launch: Stability control off, Sport Mode shifting, some wheel spin at start up but not excessive, loading torque converter to 1,200 RPM release brake with left foot and roll throttle open - I suspect this is where I'm losing time
    Troublesome / Question: My 0 to 50 time is 3.40 to 3.41 seconds, that consistent. Surprising that the next 10 MPH is taking another 1.6 seconds!
    So, given my car, the information above, is 5.01 "expected" and not bad, or am I losing time somewhere. It seems on what I've read here I should be turning around 4.7 to 4.8 with the configuration I've got and damn it 2/100th of a second are MOCKING ME.
    2009.1 Pontiac G8 GT
    New Haven, CT
    What are you using to measure the 0-60 time?
    2009 SRM GT
    Premium/Sport
    FQuick
    VIP Member norm8332's Avatar
    Near Buffalo, NY
    If you completely remove TQM it will be faster.
    My Garage
    Bothell, WA
    Quote Originally Posted by the driver View Post
    Superchips Cortex tuner off of the OBD-II interface.
    VIP Member G8GT594's Avatar
    Northville, MI
    Try it in drive. TCS off. no brake torquing. Smash to floor.
    Or if you really want to improve it, remove TQM all together.
    Can't move out its own way- idk what number motor its on, how much boost, how big of a shot, its starts, im happy.
    Bothell, WA
    Quote Originally Posted by G8GT594 View Post
    I am in drive, sport mode (not manual shift) and I am running with Stabilitrak off. With that I'm getting the 5.01. I won't run dailiy drive with torque management off, but for improved time on the track I will.
    Thanks for the feedback.
    I is teh sexy pubah grandmacpubah's Avatar
    SnoHo (WA)
    *response from the other site for the benefit of others*
    Can you graph your 0-60 time (rpms) with the cortex? If you can I guarantee you will see wheel spin on your 1-2 shift and thats why you see the quick time to 50mph.
    the best way to do these for documenting your improvements with mods is to find a spot you like...with no cops (i know hard in seattle...I go to a dead end road) and do 3-4 runs and try and get the average time. Then next mod you do like the cai...go to the same spot under similar conditions and do your runs. It gives you a great idea of what your mods are doing for you.
    Since you have the cortex you may even want to set the car back to stock just to get some baseline runs...
    for reference take the times with a grain of salt as its more about the improvement from mod to mod
    Never had a stock run but here it is
    New era otr CAI and ecm tune 4.74
    Headers and UDP (no updated tune) 4.35
    Updated ECM tune and first TCM tune 3.97
    09 Stryker Blue G8 GT *Gone*
    1 of 1,111
    Show
    20% Llumar Tint
    VentureShield ClearBra
    Matrix NanoWeb Paint Sealant
    Partial Debadge
    Red Calipers
    Forgestar F14 Gunmetal 19X8.5 19X10
    Go
    Vararam
    Vector ECM/TCM Stealth Tune
    American Racing Headers 1 3/4
    SLP 25% Underdrive Pulley
    Vector HSRK
    Billet Catch Can
    Pedders Track II W/Drop
    BMR Trailing Arms
    1/4 mile... coming soon
    0-60 3.97 per DH
    2010 F-250 Crew Cab w/6.4 diesel
    Bothell, WA
    No graphing that I'm aware of. May be able to export via USB to my computer for my analysis, don't know (someone smarter than me will have that answer I bet)
    SnoHo (WA)
    you can use my dh at the next meet and we can graph it for you...you'll see everything then.
    1 of 1,111
    Show
    20% Llumar Tint
    Partial Debadge
    Red Calipers
    Go
    Vararam
    Vector HSRK
    Billet Catch Can
    BMR Trailing Arms
    0-60 3.97 per DH
    Bothell, WA
    Nice!!!
