Be sure you get a 5 gallon tank with a low level warning, you don't want to run out of juice.
Those are nice. I only had the 2 quart tank under the hood. It would last for about 15 passes at the track...not all that bad. I would buy it by the 5 gallon jug....lasted almost a whole year. I did street race alot...
I still got about 2 gallons left....I sometimes will throw a pint in the G8 with a full tank....just trying to use it up.
gone but not forgotten
1.698 60' 11.946@113.66 BEST 60'....1.650
ENGINE....ls3 block,mahle pistons,forged rods,cloyes timing chain/tensioner,stock crank,clevite bearings,arp bolts through out.
VALVETRAINl92 heads(821casting) with lightweight exhaust valves/stainless intake valves,patriot gold dual springs/titanium locks/retainers,230/240 .595/.605 cam
EXHAUSTkooks mid length headers,no cats,magnaflow mip-pipe/resonators,no rear mufflers.
MISC..3.27 gears,spohn trailing arms,VMR V710'S....245/45-18 FRONT,275/40-18 REAR. CIRCLE D 3K
for now....'95 mystic teal ta,slightly built lt1,cam,headers,intake, tb,every suspension mod,c5 brakes,lowered,3.90 gears,corbeau seats,6-point cage,ZR1 rims.
Gotta remember though, unlike most of us, Arthur does road racing too. He could potentially use a LOT of juice in a fairly short time.
Hay wreck... There's a guy on our local board selling a brand new coolinmist varicool progressive set up. It's a $1000 kit...for $500. If your interested.
It's at alabamaracingscene.net in the for sale section.
thanks for the info 13 QTR
Gone...Goodbye..It been fun and expensive!!
No...it was to fast. One good thing about the methanol....it's the best intake/valve cleaner...you won't have any carbon build up.
The srt was designed to backfire. It actually will fire on the exhaust stroke,and it was said that it fired the injectors on the exhaust stroke to?
I never lifted while shifting..so when it hit the limiter,even thou the injectors shut off,the methanol was still spraying. So the exhaust pipes would get unburned fuel.....so that equalled a big fireball.
The only one I've used and been 100% satisfied in all of the parts and quality is the Alkycontrol kit. I've seen a few of the Devils kits and they weren't too bad, but as far as a Snow....couldn't give it to me; as a matter of fact someone did give me one once with a used turbo set-up from a Civic and it was thrown in the trash
Winning may not be everything, but its still better than losing
I don't know you. I don't know what have done. If you are looking to talk up a race for 3 hours, I can tell you I don't have the time. But what I do have are a very particular set of parts; parts I have acquired over a very long career. Parts that make me a nightmare for people like you. If you go home, that'll be the end of it. I will not look for you, I will not punk you. But if you don't, I will punk you, I will race you, and I will embarrass you.
