Results 1 to 10 of 20
Thread: Backfire from intake manifold
    Member VE HSV R8's Avatar
    Oct 2013
    Perth,That's the west side of Australia
    Default Backfire from intake manifold
    Hi all, so just finished installing new mild cam lifters oil pump timing chain and all relevant gaskets to my LS3 auto Clubsport,now I’ve sent it off to get tuned and all’s going well until it started backfiring through the intake manifold and had a bit of a miss at idle,so realised that I needed to change the plugs(oem to Tr6’s) and changed the leads (2die) and tested for vacuum leaks aswell (nothing).
    So back on the dyno,warmed up then started a pull rev’s got to 4800ish it started backfiring from the manifold..again, tuner made afew adjustments and ran again..same thing again,he reckons timing and fuel is good,we take it for a drive runs great pulls hard all the way to limiter afew times,so now just driving on freeway (speed limit 60mph) cruising in top gear floor it,it drops back two gears revs hard to 5500...bang!! Started backfiring again,we now don’t know what to do all try,so any ideas would be greatly appreciated
    Also sorry about the long drawn out story. Thank again for any help.
    Jeff
    08 HSV R8
    LS3 A6 with Camaro pan.
    3.45 truetrac,cradle inserts,
    Whiteline swaybars front & rear.
    AP Racing Brakes with QFM hex Pads all round.
    VCM OTR.
    Billet Catch Can.
    1 3/4" pacemaker extractors,200cell metal euroV cats.
    2 1/2" Manta exhaust.
    Current Mods; VCM 21 cam-217/225* 600/580 lift Crow Cams Double valve spring kit,Smith Bros trunnion bush set...425hp 450tq current tune by Shannon Summers TuneCorp,WA.
    Mods to come:3 exhaust,machined TB,more braided hoses
    12.6@110mph.
    My feeling is the cam was installed too far advanced. Was it checked when installed?
    Under more construction.
    Oct 2013
    Yeah ended up installed dot to dot which degreed at 109* and suggested install was 111*
    08 HSV R8
    VCM OTR.
    Billet Catch Can.
    12.6@110mph.
    Oct 2013
    Pulled the plugs today and found that it is running really rich and I don’t know how this will affect it but it’s going back tomorrow to see what my tuner thinks.
    08 HSV R8
    VCM OTR.
    Billet Catch Can.
    12.6@110mph.
    So the springs can't hold the intake valves closed?
    Oct 2013
    Don’t know,I thought they’d be fine,duel springs 140 on the seat and 355 open
    08 HSV R8
    VCM OTR.
    Billet Catch Can.
    12.6@110mph.
    Quote Originally Posted by VE HSV R8 View Post
    Dont know,I thought theyd be fine,duel springs 140 on the seat and 355 open
    I think what Ray is saying is that if the cam events are 2deg off, it's possible that the valve events aren't lining up correctly with fueling/spark events.
    Oct 2013
    Makes sence,I’m seeing my tuner tomorrow so I’ll let him know and see what he says,looks like I may be doing some more work over the weekend.
    08 HSV R8
    VCM OTR.
    Billet Catch Can.
    12.6@110mph.
    Makes sence,Im seeing my tuner tomorrow so Ill let him know and see what he says,looks like I may be doing some more work over the weekend.
    Ask your tuner if he adjusted eoit based on your cam... There's a dsteck spreadsheet and guide posted over on hp tuners forum.
    Oct 2013
    I’ll ask when i see him today,thanks ����
    08 HSV R8
    VCM OTR.
    Billet Catch Can.
    12.6@110mph.
