Results 1 to 10 of 13
Thread: 2009 GXP M6 Entire Instrument Cluster Shutting off while driving
    Sep 2014
    S. Florida
    Default 2009 GXP M6 Entire Instrument Cluster Shutting off while driving
    Have been searching for this same problem for days and have not been able to find much. I have an 09 M6 GXP and the entire instrument cluster will stop working(no lights, gauges, blinker lights/sound or center dig display) while driving and come back on randomly. When it goes out the gauges will freeze wherever they end up until they start working again(shutting off the car does not reset needles or anything which is strange). First time it happened several days ago they came back on withing a few seconds. Since then they went off for almost a whole day so its getting worse I think, but usually its for minutes or seconds...
    No MIL/check engine lights come up when this happens. Im thinking its either the BCM or instrument cluster going bad, but not sure how to proceed. Everything else works, all interior lights work, blinkers do work even though I can hear or see the arrows, radio and steering wheel controls work etc...
    I took a couple videos and managed to get them to stop and come back on although it had to be in 2 separate vids. Sorry for the shaking, a little hard to hold the phone and change gears at same time.
    First video:
    Sep 2014
    S. Florida
    Second video coming back on:
    No chance of it being a bad or loose ground?
    Also from what I read, you can check if it's a bcm problem by adjusting air conditioning or cruise control. The a.c. and cruise goes through bcm.
    If those features work, then I'd assume the instrument cluster is at fault. Maybe a dash disassembly is in your future.
    merca!!!
    I was just going to say it's likely the bcm resetting a relay or something. The power circuit for the lights and dic seems to wanna reset but keep signal to the instruments going.
    My radio will loose power at times and will not turn in with the key remaining on. It will fire up if I unplug it's harness and plug it back in. I have no idea why. It's got good ground and power. Never popped a fuse. No idea at all.
    2008 GT-M. PBM, #885
    Sep 2014
    S. Florida
    The ac and steering wheel controls function normally when the cluster goes out...
    Good thread, will have to try some of the things mentioned. I think the op ended up fixing the issue with a new cluster.
    Grounds all checked and good, also checked and replaced most of the fuses. Will try swapping some of the relays around next.
    Yeah I'm not sure why this is happening, hoping it's something simple but I think its just the cluster on its way out. Will take the cluster out as a last resort and check plug connection along with the BCM.
    Quote Originally Posted by G8eraid View Post
    The ac and steering wheel controls function normally when the cluster goes out... Good thread, will have to try some of the things mentioned. I think the op ended up fixing the issue with a new cluster. Grounds all checked and good, also checked and replaced most of the fuses. Will try swapping some of the relays around next. Yeah I'm not sure why this is happening, hoping it's something simple but I think its just the cluster on its way out. Will take the cluster out as a last resort and check plug connection along with the BCM.
    Based on you saying the cruise and A/C work, I'd lean cluster - hopefully a plug, but I guess I would doubt it.
    Sep 2014
    S. Florida
    Update, I have a friend that owns a cluster repair shop. We removed the cluster and he resoldered and checked everything on the cluster main board. It's still doing the same thing but now after a couple days of doing the removal/solder the speedo and tach stopped working. So Even when the cluster is on those 2 gauges do nothing.
    So I'm leaning towards the BCM being the problem.
    Well I guess there's just one way to find out.... Good luck!!
