Results 11 to 20 of 23
Thread: P0174 Issue, 09 G8 GT
    Yeah, sell it. Buy someone else's problem. That could be easier to fix.
    Under more construction.
    I hadn't considered that. That's actually quite reasonable. :-)
    Wire traced the fuel injector and coil for cylinder #2. No issues, no shorts that I could find.
    Slightly raised idle fuel pressure.
    Replaced bank2 header gasket.
    Visually watched valve train during crank to see all rockers/springs/valves moving. They were.
    No change. Bank2 climbs lean at idle.
    Jul 2010
    Castle Rock, CO
    Something in the tune?
    09 G8 GT in Stryker Blue
    Mods
    Go: Vararam CAI, SLP Headers, Magnaflow 12468 mid-muffler & PM-FL Axlebacks. Tuned by MAC Autosports of Parker, Colorado. FE3 Shocks N Struts.
    Show: Little Trees US Flag Vanilla Scented Air Freshener; SLP G8 Firehawk wheels; tinted windows
    The Track
    Best 1/4: 13.969 @ 102.70 @ Pueblo Motorsports Park, w/ DA of 3921'.
    Quote Originally Posted by wyome View Post
    I really don't think so, but that's not my forte. The tuner didn't see anything initially that is jumping out at him, but it's all remote, which is tough.
    He suggested maybe swapping the valve springs on that lazy cylinder with ones from another bank. I'm going to give that a shot at some point, but honestly I would think a valve spring issue would show up at higher rpm, not at idle.
    I went back and looked at the oldest log I have, from 2013. I had a +5 differential on Bank2 vs Bank1 at idle. I wasn't able to view a log to see if that number climbed over time, however after acceleration or deceleration and then idle (such as at a stop sign), the fuel trims drop to B1:0/B2:+5.
    This is consistent with the idle performance today, a +5 differential on Bank2.
    Going to do a hot leakdown test, and compression test. Going to check spark strength at 200deg.
    Then I'm pulling the blower and heads. Going to replace intake gaskets, lifters, springs (it's time, anyway), and upgrade to the ls9 head gasket.
    Wait! It's gonna be driving season. Turn the light off and go. Freak.
    Haha!
    Hot leakdown was fine, spark has plenty of strength.
    Its all out.
    Gutted the cats this afternoon.
  9. #19
    Haha!
    Its all out.
    I see what you're doing. You're trying to get out of working on the property. LOL
  10. #20
    Wellllllllllllll
    got it back together with new gaskets, new injectors, new springs, and new lifters... still drifts. However, now it starts Bank1 @ -3% and Bank2 @ 0% and then at about 16mins through 20 mins Bank1 will go to 1% and Bank2 will climb to 5.5-7%.
    It seems that both banks will climb slowly, but bank 2 climbs exponentially more. These trims are significantly better than before, however the drift is still perplexing.
    Things that are new:
    Blower sealant
    Head Gaskets
    Exhaust Manifold Gaskets
    Injectors
    Springs
    o2 Sensors
    removed Cats
    Inspected, no faults found:
    Pushrods
    Valves
    rockers
    piston tops
    Lifter trays
    Spark plug wires
    Ignition Coils
    Wiring and both engine grounds
    Exhaust clamps/system
    Tested Spark distance @ temp and @ startup, both fine
    Fuel crossover @ blower
    If I think about this a bit differently, because both banks technically richen up, it really could only be bottom of the engine (extremely doubtful), a fuel pump issue (as fuel rails get hot and/or fuel pump heats up), or a ridiculous wiring issue that is temperature specific (again, doubtful).
    Oh well, at least she's got new springs in her!
