Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Trunion Swap Complete
    Quote Originally Posted by joemomma View Post
    Who did you buy your Manton Kit from?
    Right from Manton! Check out the stuff they make. Holy car parts porn!
    Beyond Help tchr49's Avatar
    michigan
    Is that the ls100 kit?
    Cambridge, MA
    I bought it too, directly from Manton.
    http://rollerrockerarms.com/ls-bille...-trunnion-kit/
    AC Delco ceramic pads | ARP bolts | ATI super damper | BMR adj. rear LCAs, adj. toe rods, sub frame connectors, trailing arms + tunnel brace | Centric premium rotors | Falken ZE950 tires | GForce Engineering 750hp axles | GM Camaro 3.27 rear diff. + deep trans pan, Caprice PPV alternator and G8 GXP FE3 shocks/struts, rear diffuser + trans cooler | G8 GT mufflers | Holden door handles, onyx trim + sports steering wheel | Livernois Motorsports L92 Stage 1 Cam | Manton LS trunnion kit | Moog end links | Norris Motorsports catch can | Pedders rear camber/toe kit + poly bushings | PRC LS3 260cc heads | RCR intake + throttle body | Rotofab 102mm CAI, engine covers + radiator cover | Russell SS brake lines | Texas Speed LS3 short block | Stainless Works 1 7/8 headers + 3 exhaust | SuperPro front control arms + motor mounts
    Senior Member joemomma's Avatar
    Oct 2009
    Southern Maryland
    Ok, I had the right web site then. Any tips or tricks for making the install easier?
    Thanks...
    2009 SBM GT... 427rwhp... Best 1/4 mile 11.98@112.50...
