Results 1 to 7 of 7
Thread: LSA IC Pump Bracket
    Member PPV's Avatar
    Aug 2015
    Default LSA IC Pump Bracket
    I made a pump bracket for my LSA conversion and decided to pop out some extras. I wanted a clean install and tried to buy a magnuson bracket but would have had to source it out of Australia and you all know what a PITA that is and they never answered my inquiries to buy one.
    The bracket mounts the pump on the lower passenger side. It uses the stock coolant overflow tank bolts to secure it and hangs just below it. Similar to the magnuson setup.
    They were laser cut then powder coated and will work with the Bosch or lingenfelter varex pump. It will work on the SS, G8 and Caprice. Get them while you can.
    $55 shipped to the lower 48. PayPal
    I will consider LSA parts in trade to complete my build.
    Sent from my iPhone using Tapatalk Pro
    1970 SS454 Monte Carlo - triple black
    1970 Convertible Mont Carlo
    1970 K10 short wheel base
    1971 SS454 Monte Carlo - Red with black gut & top
    2009 Silverado 1500
    2013 9C1 - black
    Sep 2014
    S. Florida
    Pm sent
    Member PPV's Avatar
    Aug 2015
    Got a few left
    2009 Silverado 1500
    2013 9C1 - black
    Sep 2011
    2009 GXP KCMO, USA
    Quote Originally Posted by PPV View Post
    Got a few left
    Do u think it will also work with the verimax pump ?
    Also what intercooler/HX did u go with ?
    Member PPV's Avatar
    Aug 2015
    Quote Originally Posted by screaminChick-n View Post
    For some reason I can’t see the photo you posted. I am using a varimax pump. The bracket is designed to work with varimax and Bosh pumps.
    I am building an SS and designed my own HX. Not sure if the design will fit in a G8.
    I’m designing another one and I bet it fits the G8 but will require relocating the washer reservoir.
    2009 Silverado 1500
    2013 9C1 - black
    Sep 2011
    2009 GXP KCMO, USA
    Picture attached again....does ur kit come with the two rubber holders that go around the pump ?
    Member PPV's Avatar
    Aug 2015
    Yes that pump will work with the bracket.
    2009 Silverado 1500
    2013 9C1 - black
