Results 1 to 10 of 14
Thread: How to replace wheel studs?
    Default How to replace wheel studs?
    I broke a rear wheel stud while installing my winter wheels. It appears to have been cracked. And it was on the same wheel hub on which I broke one a couple years ago. The dealer replaced it, and I believe they removed the rear hub to do it. Is it really necessary to remove the hub or can they be replaced on the car?
    HSV GTS Triple Gauge Pod, GXP Rear Sway Bar and Diffuser, HSV SuperSport Steeringwheel, SOLO axlebacks, Red Hot Shift Knob, Autodim Mirror, Hood Vent Mod, Removed Intake Cover, Rotofab CAI, Cortex, Infiniti speakers, Pioneer Sub & Amp
    Beyond Help tchr49's Avatar
    michigan
    It's claimed that they can be replaced on the car, but it may require removing a small portion of the dust shield. You can rotate the hub to line up with the broken stud and drive it out.
    Boardman, Ohio
    I just did two on the wife's GT a few weeks back.
    One had been broken for about a month, then I saw a 2nd missing so it was time to fix them.
    Drilled a hole in the backing plate between the caliper mounting pads, pop off the parking brake shoe, and drive the old out and new in.
    It was actually pretty simple to do if you can live with a hole in the backing plate.
    -Greg
    VIP Member norm8332's Avatar
    Near Buffalo, NY
    You could always use a silicone hole cover or closed grommet to close the hole if you wish. The silicone will withstand being close to hot brakes.
    My Garage
    Beyond Help Darkmanx's Avatar
    ft lauderdale fl
    I replaced all 10 it was that bad.cut dust shield and get a sledge hammer to knock them out then buy one of these to pull the new studs in https://www.amazon.com/gp/aw/d/B000E...U6L&ref=plSrch
    Too many projects.
    Detroit, MI
    I would get a plug / grommet to cover the new hole and drill the back side for access
    Unless you want to proactively remove a hub in this cold weather.
    How big a hole will I need? The biggest bit I think I have is 3/8", maybe 1/2".
    Jan 2010
    Southern New Hampshire
    If the rear hubs are similar to the fronts, I'd just pull it- that way you can work on the bench (using a vise to press studs), vs sitting on the concrete floor. The fronts I did (longer studs for Brembos) were cake in the vise.
    Creature Comfort:
    XM & OnStar out, BLUESTAR in
    Show:
    debadged except GM chicklets
    custom GXP front fascia, GXP rear diffuser
    Holden Center Caps
    Go:
    VMS ECM/TCM tune, Vararam, HSRK, ARH 1-3/4" LTH, HFCs into stock mufflers, Mobil 1, Pedders low-hanging fruit
    Boardman, Ohio
    Rears are not the same as the fronts.
    I don't know the size I used, I used a step bit to make it large enough. It only needs to be large enough to fit the stud head.
    -Greg
    michigan
    Step bit is the way to go.
    .750 hole should do nicely, and body plugs that size are plentiful, but best installed from the rear of the dust shield.
