Results 1 to 4 of 4
Thread: Samco GXP silicone radiator hoses now avaliable
    Jun 2011
    Lodi, CA
    Default Samco GXP silicone radiator hoses now avaliable
    I posted this on the engine section but for us GXP owners no one makes the shorter GXP upper radiator hose anymore. If you order it will default to the longer GT hose. I worked with a friend and sent GXP hoses to Samco they just sent back proto types for me to test and are now available. So now there is a source for silicone GXP radiator hoses. For now Jeff will be the sole distributor of these hoses and his website is siliconehosekits.net
    Thanks Tom
    G8 GXP A6
    Addicted Member bracketracer's Avatar
    Dane, WI
    Can you post pics of how they look installed?
    Joe Morgan, G8 GXP Registry Organizer, G.O.N.E. Organizer
    2009.5 G8 GXP WH 6M onyx/red no roof 12.921 @ 108.89 BONE STOCK! (then), (now) 12.344 @ 110.92 with 1.688 60' at 766' DA, PB with new cam & tune 12.191 @ 112.35, 2:59 Second Lap Time Road America (Goodyear RS-As & Hawk HP Plus pads with stock rotors), 143.1298 mph NoFlyZoneMidwest 2017 1/2 mile into 20 mph headwind. RACECAR NOW RETIRED. All of these are final PBs.
    VCM OTR CAI, HSRK, Heater Hose Relocate, custom street/dyno tune by oldskoolgp, Comp Cams 224/228 .581"/.588" 112 LSA cam, LS7 lifters, PAC 1219x springs, Monster LT1S (C7 Corvette) Clutch kit, Katech C6 Hvy Dty Master & Slave Cylinders, Camaro 1LE Diff with 3.91 gears, Kooks LTHs, Solo Hi-Flo Cats & Connector Pipes, Solo Mach Balanced Catback, BMR Toe Rods, Trailing Arms, Cradle & Diff Poly Bushings, 2017 Chevy SS front & rear Brembo calipers and rotors.
    I have a set but have yet to install them!
    Dane, WI
    Do they look like they are good quality, and do they look like they will fit alright?
