Results 1 to 10 of 20
Thread: will it fit?
    Oct 2009
    Illinois
    Default will it fit?
    Hey everyone, looking for input if this setup will work. My current Drag tires are strating to crack and I'm told I shouldn't use them they are 7 years old.
    https://www.highhorseperformance.com...ial_p/3572.htm
    https://www.amazon.com/dp/B00WY0YM1C..._t1_B004SNE3VC
    thanks for your input,
    keith
    Oct 2009
    Illinois
    no input, is it bad?
    Oct 2009
    Illinois
    From the sticky that Speedracerx posted. it looks like it should work. the offset is 54 so this seems to be on the high side. but the rims I'm looking at are 17" rims. I think the hight is OK.
    Beyond Help Slizzo's Avatar
    Newington, CT
    17x9.5 +54et will fit fine, yes.
    Oct 2009
    Illinois
    hey Slizzo thank you for the update.
    Oct 2009
    Illinois
    Hello Dlizzo, I called Jegs to see if the rims would work and they said no, cause of the 5x120 Is slightly bigger 5x120.65mm
    Newington, CT
    They are indeed different bolt circle, but if you're only using them as a drag wheel then I don't see any issues. Daily driver use I would not recommend as they will be putting stress on the studs.
    Others may tell you differently, but this is just how I feel in terms of my own safety and that of my family.
    Feb 2011
    Latham NY
    The offset in bolt/hole location will result in a bending stress in the studs. Aside from plain overloading a bolt, a bending stress is the worst kind of load to put on a threaded fastener. So the studs won't break immediately, but over the miles they will start to crack.
    Oct 2009
    Illinois
    Agreed, I'm looking at options, thanks for the input. Also thank you Slizzo for the information.
    Oct 2009
    Illinois
    Ok, new plan "will it fit?".
    Tire, ET Street S/S, P275/45-18 ,Tire Diameter Range:27-27.99”. 45 is a taller tire,will this work? Most of everything I see says 40 is desired.
    Rim, 18X9,5X120 OFFSET +45
