$800
Plan ahead and save some coin!
Brand new on TireRack this setup was over $1,600. Lightly used on my recently sold 2009 Ponitac G8 GXP over the last 3 winters. Less than 10,000 total miles on them. Rims are excellent condition and plenty of rubber left on the tires. TPMS is operational and lug nuts are included. Need the room in the garage. Come and get them. Cash only.
Rims:
Finish: Bright Silver Paint
Construction- 1pc. Low Pressure Cast
Warranty- 5 Years (still under warranty)
Offset: 30mm
Backspacing: 5.67"
Bolt Pattern: 5-120
Rec. Tire Size: 245/45-18
Weight: 25.0 lbs.
TL 72.62-67.10 Center Rings included
Tires:
245/45R18
100T XL
Max Load: 1,764 lbs.
Max Inflation: 50 psi
Tread Depth: 12/32" (@7/32" remaining)
Tire Weight: 28 lbs.
Tread Width: 8.2"
Overall Diameter: 26.5"
