Results 1 to 5 of 5
Thread: Radio rear Video Input
    Member chevybernie's Avatar
    Aug 2017
    Default Radio rear Video Input
    Hi.
    Sorry, if my english is not correct. I´m from Germany and have a problem with the rear input. I have a rear camera and will operate this with the radio monitor. I had readed here in the forum that i can build a connector by myself. I´ve got all parts for it. In your description, i should connect pin 5 and 14 at the Video input connector for the Cinch connector to camera. On the foto from the install plan is a circle round the middle pins. This are not 5 and 14. Is this only for example? I have connectet pin 5 and 14, but no signal. I thought, maybe the camera is fault and tested a video player and tv for cars on the cinch connector if there comes any signal and picture at the monitor. He is only dark.
    Can anyone help me?
    Greetings from Germany
    Bernhard
    Aug 2017
    The Tread, i ´ve readed this was from 2009. From Micheal0484, but i can´t find him here to ask him directly. Can me help somebody?
    Junior Member HoLLo's Avatar
    Feb 2014
    https://drive.google.com/open?id=0Bw...3lWVlB5bzl1S2s
    Open this file, and scroll to the bottom for making aux cables. Pin 5 and 14 are correct. Pin 5 is ground, 14 is signal for rear aux video.
    | Tim R. | 09 MGM G8 GT | 01 SOM Trans Am WS6 |
    Aug 2017
    Thank you.
    You helped me so much. That was what i´m searching for. If i can do something for you here in germany, let me know.
    Aug 2017
    Camera works. Thank you again.
