Results 1 to 6 of 6
Thread: Oil pressure sender filter?
    Jun 2012
    Default Oil pressure sender filter?
    Does the G8 require this part? I'm replacing the sender, but hadn't seen anything about this filter screen??
    Northern, NJ
    I've never seen a filter on an LS oil pressure sender.
    Sent from my Pixel XL using Tapatalk
    That filter sits in the oil pressure sensor boss casting of the valley cover below the oil pressure sensor. It was my understanding that it had to do with the car having the DoD system, and was necessary because of that moreso than the sensor itself. Lemme do a search and see if I can find the thread where it was talked about...
    I searched generally on Google, and yeah, it's beneficial to the DoD system. I think you could just pull it while you're in there, clean it with carb cleaner, and if it looks good, re-install. If it doesn't, then replace it. For $6, I would go ahead and have it on hand, right?
    Senior Member TA427's Avatar
    Central Florida
    That sits under oil press sensor,and causes crazy low oil press codes if it gets even semi clogged
    2009.5 G8 GT Maverick Silver;Sport/Prem,Sunroof, Nav kit,
    Vararam,Holden badge kit, Kooks 1 7/8, VMS Tuned
    2009 White Hot/Red G8 GT;Sport/Prem,Sunroof, Nav kit,,Holden badges,Kooks 1 7/8, Maggie TVS 1900,VMS Tuned. Injection is great but i love being blown!
    2001 Trans Am WS6 NBM/Camel, 6spd. 21K Miles
    2001 G/P GT= beater
    Jun 2012
    So it's possible that this could be the actual issue. I'll definitely have one on hand.
    Quote Originally Posted by cstmg8 View Post
    Yes and yes.
