Results 1 to 10 of 15
Thread: Towing with the G8?
    Lebanon,Indiana
    Default Towing with the G8?
    I have found conflicting info on the capacity.
    GM says 2,000 lbs
    Holden says 4,000 lbs
    I am looking at towing 1,500 lbs
    The trailer is 1,046 lbs and figuring 300-400lbs of gear.
    My concerns
    I would need to be in manual mode using 5 th?
    I would need rear coil over shocks?
    How would the stall converter like it? They pull trailers during drag week!
    Has anyone used the G8 for towing?
    Here is what I am looking to tow
    My wife and I are going to try camping. Arizona has so many state and federal parks here,it is absolutely beautiful. Now I have my reservations about this. We usually only camp at the Holiday Inn.
    I have found a couple of places in Phoenix that rent this pretty reasonable. My plan is to rent one a couple of times to see how it goes.
    This is what I really want to do,however I will take baby steps toward this.
    I only planning using the G8 a few times to pull this trailer. While I want to buy a Jeep I am not ready to drain the savings or take on another car payment right now.
    I may regret this but, thoughts on my plan?
    My folks talked about one of those for a while, because they do travel quite a lot. They do the B&B thing, and largely avoid chain hotels. They went down and looked at one and that was enough... they're back to B&Bs. It was wise to take the time and give it a trial run before diving in.
    Me personally, once the kiddos are out and on their own, I think it would be really really cool to try out. Something to get you away from home and out of the ordinary - explore and teach your mind new things. It would really force you out of your comfort zone, and that would be pretty cool to me.
    Good luck to you two. If you make it up this way, it's beautiful country, and we even have warm beds to sleep in!!
    All I know is Paul always talked about how much better the Holden hitch was than the one found here in the U.S. He said it was rated for more weight. The stall and high trans temps is what I'd worry about.
    merca!!!
    The driveline will have no problem. The hitch is the weak link.
    I knew a dude who pulled a 30 foot camper with a ford torus hundreds of miles many times a year for years in pa up and down hills. Nothing broke. Just lots of front break rotors. Haha
    2008 GT-M. PBM, #885
    Senior Member GXP-G8's Avatar
    Apr 2014
    Clovis, NM.
    Just gotta get the class III hitch from Australia !
    Class I sold in USA, 1 1/4" receiver.....2,000lbs
    Class III sold in AUS 2" receiver.....4500lbs
    I tow the little G, 3,000lbs, on a dolly, see below, and no issue at all.
    I have the trans cooler on the GXP, so I'd do that at least.
    09 G8 GXP Auto, 4dr GTO 13.60@104.2 6177 DA.... tvs2300 13.2@110.2 spinnig all the way !
    07 G5 GT 2.4T Auto, Baby GTO 13.20@106.4
    @ 4200' in the sky !
    Quote Originally Posted by andrewbrooks87 View Post
    towing stuff with cars is cool !
    Lebanon,Indiana
    I have a large trans cooler already. Yeah it looks like I would need to import the hitch.
    Lebanon,Indiana
    Quote Originally Posted by GXP-G8 View Post
    Thanks. The trans cooler I have is bigger than the GXP. Did you change the shocks?
    Apr 2014
    Clovis, NM.
    Running stock shocks and springs.
    I tow in sport mode.
    Lebanon,Indiana
    Any photos?
    Apr 2014
    Clovis, NM.
