Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: LED headlamp conversion
  1. #21
    Sep 2008
    Central Illinois
    I ordered morimoto extensions. Haven't had the chance to get them in though. I think I might leave a small downward facing hole to help cooling a little, but not have the gaping hole one has with no cap at all.
    09 G8 GT SRM Premium Sport Sunroof
    HSV GTS Triple Gauge Pod, GXP Rear Sway Bar and Diffuser, HSV SuperSport Steeringwheel, SOLO axlebacks, Red Hot Shift Knob, Autodim Mirror, Hood Vent Mod, Removed Intake Cover, Rotofab CAI, Cortex, Infiniti speakers, Pioneer Sub & Amp
    Admin: www.pontiacbonnevilleclub.com
  2. #22
    VIP Member with OCD Executor999's Avatar
    Cambridge, MA
    I am also doing this project and have deliberately run a slow schedule to make sure I've thought things out. My original headlamps are so trashed that I am starting with new ones and have the liberty of mocking things up. You can see the back of the headlamp assembly here and the two dust covers.
    Here the dust covers are removed and you can see the stock lights installed.
    Compare one of the stock lights with the new LEDs I bought from Amazon.
    Here are the decoders you need in order to trick the computer to accept the lower wattage of the LED bulbs. They are definitely required for the low beams, but if you don't use your high beams often then you can get away without using decoders. I like to play it safe.
    Here are the LEDS installed, both low beam and high beam. You can plainly see that the heat sink sticks out and thus the bulb is much larger than the stock ones. This will vary depending on which brand of LEDS you get
    If there wasn't a wire sticking out of the back of the LED bulb, the dust cover would fit - albeit with not much clearance.
    I am torn between not using dust covers and modifying the stock ones so they will provide at least some protection. My current idea is to drill out the middle, add a grommet that will allow the heat from the heat sink to escape, provide space for the wires and provide some protection against moisture and dust.
    Hope this info helps your decisions. I'm glad to hear that those who aren't using the dust covers haven't had major issues.
    FYI, I bought these from Amazon after Curtis (texn884) recommended them.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Alla Lighting also makes fog light LEDs
    2008 Pontiac G8 GT | PBM | Premium Package | Tuned and Wrenched by Rick Crawford Racing (RCR)
    1" American Racing Headers | AC Delco ceramic pads | BMR adj. rear lower control arms, adj. toe rods, sub frame connectors, trailing arms and tunnel brace | Centric premium rotors | Falken ZE950 all season tires | GForce Engineering 750hp axles | GM Camaro 3.27 rear differential, Camaro trans pan, GXP FE3 shocks/struts and GXP trans cooler | Holden engine covers, onyx interior door handles, onyx exterior and interior trim, solid color exterior door handles and VE sports steering wheel | Landspeed Development stage II cylinder heads | Moog sway bar end links | Norris Motorsports catch can | Pedders rear camber/toe kit and poly bushings | RCR LS3 416 stroker engine, Lunati 223/237 .615/.601 113 +1 cam, intake and throttle body | Rotofab 102mm CAI and radiator cover | Russell SS brake lines | SuperPro front control arms
    'Charlie the GRRRR8' - Rest in Peace 11/14/2013
  3. #23
    Sep 2008
    Central Illinois
    I haven't had to use decoders.
  4. #24
    Jun 2009
    Raleigh/Cary, NC
    I know it doesn't help since I don't have a g8 but I did the same thing you are planning to do Executor999. I drilled my dust caps and used a grommet to seal them up with the wires on my Charger.
    2017 Dodge Charger R/T Scat Pack
    2015 Jeep Cherokee Latitude V6
  5. #25
    Cambridge, MA
    Quote Originally Posted by Zodiac View Post
    How did it work out Zodiac? No issues with heat build up from the LED bulb heat sinks?
  6. #26
    Jun 2009
    Raleigh/Cary, NC
    Quote Originally Posted by Executor999 View Post
    I actually am using HID bulbs. I know of several people that have done it with LED and 0 issues. I almost went for the LED, but decided HID was best for my night driving.
  7. #27
    Cambridge, MA
    Quote Originally Posted by J Wikoff View Post
    I didn't see your post the first around. What brand of LEDs are you using? I will test mine without the decoders first.
  8. #28
    Sep 2008
    Central Illinois
    They are Nighteye. I think I linked them above. I put the same ones in our Town & Country and it did need the decoders.
  9. #29
    Sep 2008
    Central Illinois
    So today I went through the carwash. I've done it several times since putting in the LEDs and leaving the dust caps off, but this time I used a different place that happens to have stronger underbody sprayers. Tonight, I have horrendous condensation in the headlights. I'm sure there will be spots and run marks in the morning.
