Results 1 to 6 of 6
Thread: Rear abs wire harness replacement cost.
    Senior Member astynx's Avatar
    virginia beach, va.
    Default Rear abs wire harness replacement cost.
    Hello, I have the " abs fault-traction control off light " on again. On Star said code C0045. Which is left rear abs wheel speed sensor. This has been replaced once previously. Also had right abs wheel speed sensor has been replaced. Both in the last two years. Does anybody have any idea what dealer would charge to replace rear abs sensor wiring harness ? GM Part # 92257573. I may just take car to dealer. It is just so hot now to mess around with it myself. I just wanted to have an idea of how much that they will soak me. That is if it is a wiring connection problem. Also if anybody has installed this harness how easy or difficult might this be? Thanks.
    Moderator LDM's Avatar
    Mar 2010
    Cape Cod, MA
    I don't know what a dealership would charge but I did it myself awhile back and don't recall anything too difficult about it. A lift would make it even easier but I did it on the floor with jack stands.
    Len
    Northern, NJ
    I have a rear ABS harness. PM me a fair offer if your interested.
    I removed it from the cradle while it was out so I can't help you on the install time.
    Sent from my Pixel XL using Tapatalk
    virginia beach, va.
    Thanks for the quick replies. I'll probably take it to dealer. I need to get it fixed somewhat quick. Car isn't my dd but G8 has to be ready if something happens to my dd. Also it has been a couple of years or so since I had a significant car repair expense. I guess I am about due.
    Someone with access to Alldata should be able to get the book hours for that. Labor was $90 an hour in Indiana, but looks to be $120 an hour in Texas.
    Under more construction.
    virginia beach, va.
    It should n't be alot of labor. Anyways, started car this morning no abs,traction control off warning. Drove around a bit with a few ignition off and on and warning was still off. Who knows, it may just pop back up. I will probably buy new harness and when car is up on jackstands for yearly oil change. I will replace with brand new harness. Thanks again for replies.
