Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Russell 692210 stainless lines
    One of mine rounded off very easy and the car was only a year or two old at the time, and I gave up. It wasn't till a couple years ago that I finally replaced that hard line and swapped the hoses.
    Beyond Help tchr49's Avatar
    michigan
    Well...
    This. My comment wasn't an indictment on how you use and maintain your car. More of my experience with the materials GM/Holden used. When I did my brakes, I wanted to do everything at once. Bought calipers, rotors, pads and lines. Got everything on but the lines. Maybe, one day....
    Exactly and well put. I was amazed when I saw how the line connections had fuzzed up. Couldn't believe they were on my car. I believe they would round very easily. Inexpensive tools are usually that way for a reason, and flex/give in the wrench will ruin your day.
    Anyhow, the Russell lines are quality pieces.
    Sep 2011
    No offense taken...
    Just trying to figure out if I need to pickup these Russell lines when I finally get to this upgrade....
    Well...
    michigan
    Front brake lines from Advance, etc, are going to retail for about $28 each. They are exact replacements.
    Didn't price the rears. You can always get 20% off if you order online, but the whole kit from Greg at Pace was only a little over $100.
    Dec 2015
    Easily the best $115 mod you can do to your car. I was worried about rounding them off too, but I soaked them all with pb blaster and let them soak while changing the oil. Them I bought a small handheld torch from lowes and put the heat to them before I even tried to loosen them and then used a line wrench and was able to get them all off with no problem. The heat is the key.
    '09 WH G8 GT
    Premium/Sport
    Red/Onyx
    Rotofab CAI
    Cortex 93 tune
    20% tint
    I just wanted one.
    Member slayermanny's Avatar
    Mar 2012
    Miami, FL
    All I did was hit them with PB blaster the day before. Good flare wrench as well. My labels were right when I did my zl1 conversion last month.
    michigan
    Quote Originally Posted by slayermanny View Post
    Yup, labels are now correct. I did get new copper washers instead of using the aluminum ones that come with the lines though.
