Results 1 to 7 of 7
Thread: Speed bleeders yes or no?
    Beyond Help tchr49's Avatar
    michigan
    Default Speed bleeders yes or no?
    Two questions.
    Are speed bleeders worth it, and does anyone know if a brake system flush can be done with them in place.
    Talked with one of the few places I would trust to do a brake flush, but they were unsure if the pressure of their machine would work with the check valve arrangement in the bleeders.
    Feb 2011
    Latham NY
    IMO not worth it.
    I use a ASTRO Pneumatic vacuum pump (large plastic cylinder with a piston that you manually stroke to develop a vacuum). Hook a plastic tube to the bleeder valve on the caliber and open the valve. The brake fluid is drawn out of the caliber and into the vacuum pump cylinder. Just did brake fluid flushes on 3 vehicles last year by myself. No pumping of the pedal needed as the vacuum draws the fluid from the reservoir. Just keep the reservoir full with new brake fluid.
    IMO not worth it.
    Agreed.
    Under more construction.
    Nov 2009
    I also don't think the speed bleeders are worth it. I use a Motive brake bleeder and it works great. It's the opposite of how @whatnext's vacuum bleeder works, it actually pushes the old fluid out while replacing it with new fluid. Works great and easy to use with only one person. The advantage of the vacuum bleeder over the pressure bleeder is that with the pressure bleeder like mine you have to buy an adapter that fits onto the brake fluid reservoir (different adapters for different cars) to form an air tight seal and with the vacuum bleeder you just need the bleeder and no adapters.
    Terry Scott
    Roto-Fab Intake with Amsoil Dry Filter / HSRK / Kooks 1-7/8 Mids / SOLO Mach Shorty (Unbalanced) Catback/ Pat G Tune / Norris Motorsports Gen2 Catch Can / BMR Swaybars / BMR Rear Trailing Arms / Tein S-Tech Springs / Koni Shocks & Struts / Whiteline Rear Cradle Bushings / Whiteline Strut Bushings /
    400 RWHP / 391 RWTQ
  5. Thanks -Ray- thanked for this post
  6. #5
    Yeah I would pass. Often they work for a while and then open potential to leak - or worse some cause clearance issues.
    Having used both the vac system - and now owning the motive pressure bleed system. I like the motive best. it costs a little bit more to get into but damn it works well.
    and clean and faster. Now I say faster - since you can put pressure there - you can also keep it on for a while - also helps spot leaks you won't find if you vac bleed. which is good when you do a full line swap.
    so if I was going to put a bit o money into something - I'd put it toward a motive system - or one like it. Or consider a DIY fab - which I also thought about.
  7. #6
    Sep 2014
    S. Florida
    There are also the fairly new one person reverse bleeders, I just learned about them recently and haven't had a chance to use one yet. They look promising... I think it's the only one that will bleed abs brakes without scan tool and do reverse, vacuum, pressure and bench bleeding all with the same tool.
    https://www.amazon.com/Phoenix-Syste.../dp/B00GRV800S
    I went with speed bleeders originally when I installed my 6pot V2 calipers and haven't had a problem with them yet. Just recently purchased a Motive kit for $50. Thinking I should of probably went with a reverse Bleeder but not 100% sure if it will actually get air out of our abs system.
  8. #7
    sorry but that line about "only system to bleed ABS ..." is BS. Maybe on older basic ABS systems but I still wouldn't trust it. Why - ABS controllers are fail safe open - meaning in any condition the lines to the calipers are open - though to the master cylinder.
    so untill you work those valves - you don't get to the fluid behind them - and you can't magically push fluid though them. Some ABS controllers also have check valves in them for one way flow - this won't do squat for that.
    the best way to bleed out and flush a modern ABS car is though the master cylinder though to the calipers - the way the system was meant to work - and to then take the time to flutter the controller and re flush.
    What the reverse system is really good at though - filling an empty caliper - and path though to the MC on a car without requiring a bleed. However again for the money I'd buy a pressure pot system which would so the same or similar thing
