Results 1 to 10 of 11
Thread: Found this rattling around, anyone recognize it?
    VIP Member BATOYGIO's Avatar
    Nov 2009
    Queens, NY
    Default Found this rattling around, anyone recognize it?
    I found this rattling around in my front splash shield (the center one under the bumper)....anyone recognize it to know where it came from?
    '09 Liquid Red GT
    Kooks, VMS, Roto-Fab, Solo, BMR.
    12.86@109 1.98 60ft
    I think that is a front suspension shim. Goes where the control arm connects to subframe.
    merca!!!
    It'd definitely a front alignment plate.
    If you. Had work done they likely dropped this when they (hopefully) replaced them.
    Did you. Have an alignment or new control arms?
    2008 GT-M. PBM, #885
    Looks like a stock caster washer for the radius rods.
    Feb 2011
    Latham NY
    +1. It's the caster plate/washer. It's stock as the hole is centered.
    Dec 2015
    Jesus. At $38 a piece, I hope you kept it.
    '09 WH G8 GT
    Premium/Sport
    Red/Onyx
    Rotofab CAI
    Cortex 93 tune
    20% tint
    I just wanted one.
    That's a pair and they're not stock.
    Nov 2009
    Queens, NY
    Thanks for the replies, I did keep it. I had my Lower control arms changed and an alignment done. The car was all in spec after the alignment, I saw the sheet. Should I be worried? If the car passed alignment, and everything is tight under there, was it needed?
    '09 Liquid Red GT
    12.86@109 1.98 60ft
    No! It'd be clunking like mad if nothing was there!
    I'm sure they put new ones in.
    Nov 2009
    Queens, NY
    I had them install the LCA kit from Pace Performance, and I don't think the kit comes with any hardware other than 4 nuts and 4 bolts.....So you think they would have extra of those laying around the shop to use?.....The cars not clunking like crazy though...
    '09 Liquid Red GT
    12.86@109 1.98 60ft
