Where did you purchase you rear aux cables?
A programmer is required to enable a Version 9 radio for back up camera, not just changing setting on radio?
I made them. Details are in the guide.
Wiring into the board itself and flashing files is required to upgrade to V9. I'm working on that now and am 50% there, but have hit a road block because I damaged something and trying to find a spare part. Won't be a permanent road block. Stay tuned.
| Tim R. | 09 MGM G8 GT | 01 SOM Trans Am WS6 |
I bought these:
http://www.ebay.com/itm/Pontiac-G8-V...53.m1438.l2649
Terry Scott
2009 G8 GXP - Sport Red Metallic (#821 of 1829 / #33 of 74 as Optioned)
Thanks, just ordered the cables, did you also install a rear camera? What kind?
Yes, I installed this camera: https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
So far so good. No complaints about the camera.
Terry Scott
So many projects, so little time.
Sent from my LG-D851 using Tapatalk
RIP Charlie - GRRRR8Originally Posted by TonyKarter
Thank you very much for posting this. It was a massive aid in allowing me to enable VIM myself! Ran into a couple issues with the drivers throughout the re-programming process on a laptop with windows 10, but unplugging and starting from the first step, it eventually worked itself out.
I really appreciate the time you have put into the google doc. Instructions were perfectly clear throughout entire process. Ended up buying a VIM Cable with Reverse input (luckily have a V9 Radio) instead of making my own.
Side note the antenna on the left side of the radio is a huge PITA to unplug. Everything else went seamlessly. Thanks again!
2009 G8 GT
628.5 RWHP on gasoline ---> ARH Long Tubes 1 7/8" & full exhaust / Magnaflow Mid Muffler / Cherry Bomb Vortex Mufflers / Magnuson 1.9 / Overdrive "non-cog" pulley system / Ported blower base / 2.70" Pulley / LS3 rockers with Trunion upgrade / Trick Flow x255 cylinder heads / 8-Rib Pulley system / Innovator West 10% Balancer / DOD Delete / Lunati Lifters / Custom CTS-V Patrick G Cam Grind / Wiseco Forged Rods & Pistons / Injector Dynamics 85lbs / 4.25" Air Intake Tube / 102mm TB & MAF Tube / 102mm TPIS Throttle Body / LS7 MAF Card / ZL1 Fuel Pump / JMS Fuel Pump Booster / VaporWorx Controller / B&M Tranny Cooler with fan / Circle-D Heavy Duty Rebuild & 265mm triple Disc Billet Converter / Camaro Tranny Pan/ Eibach Lowering Springs / BMR Front & Rear Sway Bars, LCA's, Control Arms / DBA 4000xs Rotors / Hawks Ceramic Pads
