Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 41
Thread: HOW TO: DIY VIM unlock, enable Reverse Cam for v9, and other radio tweaks
  1. #31
    Richmond, a.
    Where did you purchase you rear aux cables?
  2. #32
    Richmond, a.
    A programmer is required to enable a Version 9 radio for back up camera, not just changing setting on radio?
  3. #33
    Junior Member HoLLo's Avatar
    Feb 2014
    Quote Originally Posted by jscruick View Post
    I made them. Details are in the guide.
    Wiring into the board itself and flashing files is required to upgrade to V9. I'm working on that now and am 50% there, but have hit a road block because I damaged something and trying to find a spare part. Won't be a permanent road block. Stay tuned.
    | Tim R. | 09 MGM G8 GT | 01 SOM Trans Am WS6 |
  4. #34
    Nov 2009
    I bought these:
    http://www.ebay.com/itm/Pontiac-G8-V...53.m1438.l2649
    Terry Scott
    Roto-Fab Intake with Amsoil Dry Filter / HSRK / Kooks 1-7/8 Mids / SOLO Mach Shorty (Unbalanced) Catback/ Pat G Tune / Norris Motorsports Gen2 Catch Can / BMR Swaybars / BMR Rear Trailing Arms / Tein S-Tech Springs / Koni Shocks & Struts / Whiteline Rear Cradle Bushings / Whiteline Strut Bushings /
    400 RWHP / 391 RWTQ
  5. #35
    Richmond, a.
    Thanks, just ordered the cables, did you also install a rear camera? What kind?
  6. #36
    Apr 2014
    Quote Originally Posted by terryscott621 View Post
    You may want to look in the for sale section of the other forum for a quality product at a good price!
  7. #37
    Nov 2009
    Yes, I installed this camera: https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
    So far so good. No complaints about the camera.
    Terry Scott
    400 RWHP / 391 RWTQ
  8. #38
    So many projects, so little time.
  9. #39
    Mar 2017
    Michigan
    Thank you very much for posting this. It was a massive aid in allowing me to enable VIM myself! Ran into a couple issues with the drivers throughout the re-programming process on a laptop with windows 10, but unplugging and starting from the first step, it eventually worked itself out.
    I really appreciate the time you have put into the google doc. Instructions were perfectly clear throughout entire process. Ended up buying a VIM Cable with Reverse input (luckily have a V9 Radio) instead of making my own.
    Side note the antenna on the left side of the radio is a huge PITA to unplug. Everything else went seamlessly. Thanks again!
  10. #40
    Friendswood, TX
    Quote Originally Posted by HoLLo View Post
    I was able to figure out how to flash VIM unlock, and enable Reverse Cam option for V9 radios, the two difficult radio tweaks that everyone keeps secret. Big thanks to my friend Nic Powell that helped contribute data and bin files for me to flash my radio countless times and figure this out. Please share this with anyone who wants this information, I did it for the car modding community, not for profit.
    As always, you perform these mods at your own risk, I am not responsible for any possible damages you cause to your car. Read it thoroughly before attempting anything.
    There are plenty of vendors who sell boxes that plug into your OBD2 port that can also perform these tweaks, so if you are unsure about removing your radio and programming an EEPROM, you have options to reach out to online vendors, but now you have a real DIY choice. Enjoy.
    Do not download the file, just bookmark it since I will be evolving it as I add more information to the guide.
    EDIT: I've had many questions about this. Version 9 is ONLY needed for the factory Reverse Camera feature. All other mods can be performance on ANY version radio.
    https://drive.google.com/file/d/0Bwy...B5bzl1S2s/view
    How does one find out which version radio you have?
    ARH Long Tubes 1 7/8" / Magnaflow Mid Muffler / Cherry Bomb Vortex Mufflers / Magnuson Supercharger 1.9 / Ported blower base / 2.8" Pulley / LS3 rockers with Trunion upgrade / Trick Flow LS3 cylinder heads / Overdrive "non-cog" pulley system / 8-Rib Pulley system / ATI Super Damper / DOD Delete / Lunati Lifters / Custom Patrick G Cam Grind / Wiseco Forged Pistons / Injector Dynamics 85lbs / 4" RotoFab Intake Tube / 90mm MAF Tube / VMax 90mm Ported Throttle Body / LS7 MAF Card / ZL1 Fuel Pump / JMS Fuel Pump Booster / VaporWorx Controller / B&M Tranny Cooler with fan / Circle-D Heavy Duty Rebuild & 265mm triple Disc Billet Converter / Camaro Tranny Pan / Custom Engine & Tranny Tune by Patrick G / Eibach Lowering Springs / BMR Front & Rear Sway Bars & LCA's / Moog Front Control Arms / DBA 4000xs Rotors / Hawks Ceramic Pads / Breyton BE Wheels
