Results 1 to 3 of 3
Thread: keyfob and remote start
    Member Rubberman's Avatar
    Oct 2016
    Evansville, Indiana
    Default keyfob and remote start
    ok i've had this happen several times and cant figure out why. But if i remote start the G8 and minutes later come back to use and try to unlock it nothing will happen. I cant open the trunk either or lock the car. Tried on both fobs and nothing works. if i hit the remote start button to turn the engine off then the buttons will work again and i can unlock or open the trunk. doesnt happen all the time.
    that's a new one. so to start you are having to press lock first - then start - and car starts. Exterior corner lights are on, engine running.
    If you take key and go to door lock and turn the lock with the key - what does the car do?
    when you press any other button on the fob, with car running - what does it do - how far away are you.
    Oct 2016
    Evansville, Indiana
    i can unlock the car with the key but it will set the alarm off. nothing happens when pressing any button. i can walk around the car and it wont unlock. BUT if i depress remote start then the car shuts off and then the buttons work. did it again this morning.
