Page 8 of 14 FirstFirst ... 678910 ... LastLast
Results 71 to 80 of 134
Thread: Manufacturing DA - A New Chiller
  1. #71
    Sep 2009
    VT
    Done. Very easy install and works great.
    [IMG]20170730_153349 by jon mal, on Flickr[/IMG]
    [IMG]20170730_153335 by jon mal, on Flickr[/IMG]
    [IMG]20170730_153330 by jon mal, on Flickr[/IMG]
    Sport /Premium
  2. #72
    Keep heat exchanger? Reservoir size? Drivability impact?
  3. #73
    Friendswood, TX
    Nice!
  4. #74
    Sep 2009
    VT
    It's currently plumbed without heat exchangers in the loop. I have to admit, been a while since I put the LSA on and needed a refresher on my work-of-art plumbing. I have a small reservoir off a gt500, at most two quarts. I have not run the car on the street yet, so no drive comments. I can state, with the HX, when idling in driveway, the IAT only went up until you started moving. With this system, while recharging the r134 -the IAT went down.
    That all typed, the plan will be to keep my gt500 (2in version), delete the CTSV Hx and control with a 3 way valve off a prius.
    I do want to reinforce how easy the install is. The machined parts fit perfect, the attachment to the frame rail is effortless.
    Sport /Premium
  5. #75
    Nov 2011
    Cincinnati,OH
    I really appreciate this kind of feedback! Thank You!
    Phillip M.
    Engine: Stock Bottom End
    Cam: BTR IV PD
    Drivetrain: 6L80, Sonnax
    High Compression/Boost/E85
  6. #76
    Sep 2009
    VT
    Ran some chores, sure was different watching the IAT temps. Here is an snapshot of my temps after 20minutes of around town driving. The outside temp is about 82 as the ambient sensor is dangling in the plastic support. Looks great to me.
    [IMG]20170731_113017 by jon mal, on Flickr[/IMG]
    Sport /Premium
  7. #77
    What happened to this?
  8. #78
    Sep 2009
    VT
    FWIW, the chiller from Phil has been bullet proof. Works as advertised.
    Sport /Premium
  9. #79
    Nov 2011
    Cincinnati,OH
    Still making them and selling through my website. I've revised the tubing routing to give a bit more clearance around the fog lamp on the SS. The kit works on all G8/PPV/SS applications.
    I just finished up a -10 evaporator today that is desitined for a GXP. (Pictured on the right).
    I've been really busy lately on also working on a C6/ZR1 application. I also have some dyno and track time planned in next few weeks on my G8.
    Sent from my SM-G930P using Tapatalk
    Phillip M.
    Cam: BTR IV PD
  10. #80
    Quote Originally Posted by Phil@PnP Tech View Post
    The first 10 were sold/shipped?
