This thread is great!
added coolant yesterday.
whoever has this kit whos it working? whats the before and after iat at track
Phillip M.
Engine: Stock Bottom End
Cam: BTR IV PD
Drivetrain: 6L80, Sonnax
High Compression/Boost/E85
What was the ambient temps on those runs
Hey Phil, Still taking forum discounts? I'm interested in your setup for sure.
Pat G Tune & DOD cam, Rick C TB, LSA, Ported Heads, Circle D 2600 Stall
OBX Exhaust, SLP UDP,H&R springs, Koni Shocks
BP catch can, BMR Bushings/suspension/chassis
V Brembo's, Slotted/Drilled Rotors, 3.27s Gears
Bolt ons Street tires
12.649@107.817 60ft 1.96 Da 700ft
Heads/Cam pre stall Street tires
12.16@114.21 60ft 1.75 Da -200
After Stall
11.82@115.9 60ft 1.66 DA 400ft
Zex 125shot
11.48@124 60ft 1.83 DA 2000ft
Phillip M.
Cam: BTR IV PD
