Results 1 to 4 of 4
Thread: Base to V8 is it worth it (the effort)
    Oct 2015
    Southern Vancouver Island
    Default Base to V8 is it worth it (the effort)
    Have a V6 it's ok, saw an engine for sale with trans. (v8) anyone been down that road, is there a whole poop load of extra costs involved - ex:- suspension differences, computers, obviously there is air intake, exhaust, engine mounts is a good one - I have to assume the rad. could be different too.. any one fear the topic - I have to evaluate the $$$$ so If you're bored and want to through some info. my way please doooo...
    Raleigh/Cary, NC
    There is someone on the other board that did it. Might want to hit him up about it.
    2017 Dodge Charger R/T Scat Pack
    2017 Jeep Grand Cherokee Altitude 4x4
    Hassan did it because he had a ton of money in his car already so he decided to just do the swap.
    Member norton13's Avatar
    Jan 2013
    Toronto
    Quote Originally Posted by Uplands View Post
    At least 2 people have done it, unless you have a lot of money & patience t is probably not worth it. I have both so maybe i am impartial.
