Results 1 to 10 of 12
Thread: Advise to keep front side blinker light always on . Any ideas ?
    Jan 2017
    Default Advise to keep front side blinker light always on . Any ideas ?
    I want to reduce the wattage( no melting plastic ) and change color. I also want it to be usable as a blinker as well as staying on when blinker is not engaged.
    Too many projects.
    Detroit, MI
    what blinker.
    rewire it to stay on and only engage when the other signal wire grounds it, its only 2 wires. Ground + signal.
    2009 Saab 9-3 Combi / 2.0T
    Jan 2017
    The blinker that has small black plastic mesh behind it. So , If i take it to an electrical shop, it should be easy ?
    May 2015
    Azusa, CA
    There is a module that the Harley guys use to take a regular led and give it a low voltage and higher voltage signal to produce the effect you are looking for. info:
    http://www.customdynamics.com
    Eclipze2® Module - http://www.customdynamics.com/eclipze_module.htm
    $24.95 for pair
    Eclipze2® Module
    Color change though that might be a larger job.
    Jan 2017
    @smwalker - Perfect...Thanks !!!!! Good info... Is that side light LED ?
    May 2015
    Azusa, CA
    I am not sure for the G8's. this info was used for the Caprices that do have LED side lights in AU.
    Member chevybernie's Avatar
    Aug 2017
    Question:
    Is it allowed in USA, to change Blinker( Turn signal) or other Bulbs Colors? I´ve seen in US Catalog Fog lamps, or Angel Eyes Rings, and other nice Led Lamps for Cars and Motorbikes that can change colors, or even in purple, green , or other colors. Here in germany you can´t change a stinky normal Backlight, or Blinkerbulb to a LED Bulb in Red for rear, or Orange for Blinker. If you get in a police control , than is it a big problem.
    Beyond Help texn884's Avatar
    Helotes, Texas
    that bites for sure
    Quote Originally Posted by chevybernie View Post
    Question:
    That is all illegal in the USA as well, yet people do it. You may get pulled over for it, but many get away with it. If you get in an accident and the cause is found to be illegal lighting good luck with the insurance company.
    Aug 2017
    Thank you for answering.
    I thought, only in germany is it so extremely. For example: in the 90´s i had a 82´Pontiac Trans Am. In USA Corvettes C4 and others had on roof a third brake light and i would install such a part in my car. No chance. The control office ( in germany TÜV) said it is not enable, because other drivers can think there comes a train and it is forbidden. One year later it was allowed and suddenly a big part for security. Now if it doesn´t light, you have a problem. Now on my G8 are wheels 265/45 front and 285/45 back , but not in the car papers. I drove to TÜV and asked if they can write it in the papers. I have opinions for the alloy wheels Schnitzer for BMW( fits G8), opinion for the tires and wheel spacers. All extra for front and back. No chance. Opinion must be for G8, or i must buy american wheels that fit. The new problem: american have no opinion and no letters for capacity poured or taken in. Now i driv illegal too.
