Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Popping in front.
    What's that casting number? There are different numbers on the updated LCAs. Posted around here somewhere.
    Member Rubberman's Avatar
    Oct 2016
    Evansville, Indiana
    this is just a general pic from google. not my actual car. end links are new on my car.
    Mar 2014
    Moyock, NC
    How did you torque the LCA's. Below link is for the new LCA's with GM part numbers.
    http://paceperformance.com/i-7138834...l-arm-kit.html
    Friendswood, TX
    Quote Originally Posted by Cooper View Post
    Attachment 27522
    The Lower and upper control arms look original-recommend replacing, can cause this issue.
    also your sway bar end link looks dry, I would replace that also.
    Cooper is giving your "sound" advice.
    Recently had the "very same" problem
    a) replaced both upper and lower control arms - it's not too hard.
    b) replaced end links - walk in the park!
    c) Problem "gone"
    ARH Long Tubes 1 7/8" / Magnaflow Mid Muffler / Cherry Bomb Vortex Mufflers / Magnuson Supercharger 1.9 / Ported blower base / 2.8" Pulley / LS3 rockers with Trunion upgrade / Trick Flow LS3 cylinder heads / Overdrive "non-cog" pulley system / 8-Rib Pulley system / ATI Super Damper / DOD Delete / Lunati Lifters / Custom Patrick G Cam Grind / Wiseco Forged Pistons / Injector Dynamics 85lbs / 4" RotoFab Intake Tube / 90mm MAF Tube / VMax 90mm Ported Throttle Body / LS7 MAF Card / ZL1 Fuel Pump / JMS Fuel Pump Booster / VaporWorx Controller / B&M Tranny Cooler with fan / Circle-D Heavy Duty Rebuild & 265mm triple Disc Billet Converter / Camaro Tranny Pan / Custom Engine & Tranny Tune by Patrick G / Eibach Lowering Springs / BMR Front & Rear Sway Bars & LCA's / Moog Front Control Arms / DBA 4000xs Rotors / Hawks Ceramic Pads / Breyton BE Wheels
