Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
Thread: Getting ready to do PPV struts. Spring opinions needed.
    Nov 2013
    Default Getting ready to do PPV struts. Spring opinions needed.
    I'm getting ready to do the PPV struts on the wife's G8 GT and I'm debating if I want to do Springs or not. The front end is pretty tight gap wise I assume the mounts are collapsed. Looking to do either Whiteline or the Pros from BMR. This will most likely raise the front end.
    I'm thinking the Eibach Springs because of the minimal drop I've read roughly 1". I don't want to make the ride too rough but firm "euro" style handling is desired.
    Also as an option (outside chance it works) I have my old Camaro SS Springs off of my '13 1LE. Does anyone have insight if that is feasible?
    Any advice that can be had is appreciated.
    Feb 2011
    Latham NY
    No need to assume if your strut mounts are collapsed, probably are, but just look at the gap between the top of the strut tower and the round disk.
    I have PPVs on stock springs. Everything else is stock except for poly strut mounts. Wish you had the chance to ride/drive a G8 with this combo before deciding. I am totally satisfied with the ride/handling of this combo. I did not even consider changing to lowering springs (which are stiffer than stock) because of the road conditions here in the NE. Even with 18 inch tires (Pilot Sport AS3s), I feel the ride is right on the borderline for comfort.
  3. Likes firefighter liked this post
  4. #3
    Nov 2013
    Thanks for the info. How are the tire to wheel well gaps? Are you running stock diameter Tire? If you have any pics I'd really appreciate it.
  5. #4
    Feb 2011
    Latham NY
    My G8 only has 35k miles so it is practically new. The gaps above the tires look like a new car (big, probably 1.25 inches or so). Sorry I'm away from home for another week so I can't even email you any Picts I have on my home computer. The wheels are the stock 18s.
    Come to think of it, Executor999 has pics of my G8. He was dialling back his suspension mods to deal with the crap roads after moving to the NE. So what is comfortable has a lot to do with the road conditions in your region.
  6. Likes firefighter liked this post
  7. #5
    Cambridge, MA
    Here's the pics of WhatNext's G8. Essentially it is stock ride height.
    WhatNext, just let me know and I will take them down.
    2008 Pontiac G8 GT | PBM | Premium Package | Tuned and Wrenched by Rick Crawford Racing (RCR)
    1" American Racing Headers | AC Delco ceramic pads | BMR adj. rear lower control arms, adj. toe rods, sub frame connectors, trailing arms and tunnel brace | Centric premium rotors | Falken ZE950 all season tires | GForce Engineering 750hp axles | GM Camaro 3.27 rear differential, Camaro trans pan, GXP FE3 shocks/struts and GXP trans cooler | Holden engine covers, onyx interior door handles, onyx exterior and interior trim, solid color exterior door handles and VE sports steering wheel | Landspeed Development stage II cylinder heads | Moog sway bar end links | Norris Motorsports catch can | Pedders rear camber/toe kit and poly bushings | RCR LS3 416 stroker engine, Lunati 223/237 .615/.601 113 +1 cam, intake and throttle body | Rotofab 102mm CAI and radiator cover | Russell SS brake lines | SuperPro front control arms
  8. Likes firefighter liked this post
  9. #6
    Nov 2013
    Are those stock diameter tires? That gap is way more than I have out back. Not complaining or criticising. Just surprised. I bought my car used with 10K miles and now I'm wondering if it has springs... there's nothing that will make the rear drop is there? I mean similar to the strut mounts up front.
  10. #7
    Nov 2013
    I just dug up an older picture. The wife is at work with the car. Maybe the gaps are bigger than I'm thinking. I know the front is lower than this pic.
  11. #8
    Mine has stock original springs (for now), and at 75k, is looking lowered relative to Whatnext's. I'll be putting in PPVs, Teins, and SuperPro Polylast strut mounts (they aren't the stiff polyurethane). I figure it may go down a little, but not as much as the advertised drop.
    HSV GTS Triple Gauge Pod, GXP Rear Sway Bar and Diffuser, HSV SuperSport Steeringwheel, SOLO axlebacks, Red Hot Shift Knob, Autodim Mirror, Hood Vent Mod, Removed Intake Cover, Rotofab CAI, Cortex, Infiniti speakers, Pioneer Sub & Amp
  12. #9
    Feb 2011
    Latham NY
    Executor999, thanks for posting the pics to help a fellow G8'r out.
    My wheels/tires size are the stock 245/45-18s. The gaps are pretty much the same as pics I took back in 09. Nothing in the back that will change the height like the strut bushings but springs do relax with the miles. Some more than others. See J Wikoff's comment about looking lowered compared to mine, he has double the miles that I have.
  13. Likes firefighter liked this post
  14. #10
    Nov 2013
    My car is hitting 60K. I'm going to have to look at it better when it gets home.
