Post Thanks / Like - 0 Thanks, 5 Likes, 1 Dislikes
Opps, did not mean to hit disliked.
2009 G8 GT MGM.
Kermit
Lol
No prob.
Nice 1/4 mile time you have there.
I'm looking forward to running mine. What fuel are you on ?
I have very similar mods but stock heads .
Stock gears but I have a zl1 converter .
My Tvs hits about 9psi. 9.5 according to aeroforce
Maxspeed96ct
I ran on regular 93.
Ported heads and Maggi is giving me 10-12 PSI according to my Aeroforce.
2009 G8 GT MGM.
So I did some test pulls this weekend with the Bosch pump.
Worked great, was about 45* out.
I started the log high at 82* due to some previous pulls, but I wanted to simulate a real world temp.
I did a wot 2nd, 3rd, and 4th gear pull and iat never spiked. Highest it got was 95* at the top of 4th
With the factory setup the iat would be low but during a wot pull in boost it always spiked over 100 quickly when I watched the aeroforce. I don't have any actual logs though unfortunately.
Extremely nice setup!!!!!
Never thought of using the spare tire space for a tank. That looks awesome! Nice work.
Sent from my Nexus 7 using Tapatalk
09 PBM G8 GT
Livernois Stage 1c Cam (218/229 117LSA), Ported Heads & Valve job, Ported TB & Intake Manifold,
DOD Delete, Kooks Mid-Length Headers, Corsa, Roto-Fab CAI,
Pedders SuperCar Coilovers with some BMR & Spohn mixed in,
Lots of Holden parts
Impressive!! Would it be too intrusive to ask for price points on all this? It's just too damn nice not to. :-)
Maxspeed96ct
Lol
No prob.
No kidding!!! Kermit! ....that is "serious steam" you are running there brother!
Nice, I'm planning on doing this as my high IAT's are causing my computer to pull about 4 degrees timing at the top of the track. Planning on getting one of those wheel well tanks, noticed a lot of them have a Rule bilge pump and i've heard bad things about them for street use, but also have a tough time justifying the cost of a EMP pump. Meant to do all this over the winter and redo my intake as well but spring got here fast...
LS3 - Livernois 1C cam - Joker ported LSA - Vaporworx - e85 - 2.55 upper / stock lower
PB: 1.63 60' 10.51@133
