hi all...
so i want to install a single din in dash unit where the cigarette lighter is. only problem is, once you remove the panel where the cigarette lighter is, there's a hard plastic tube leading from the hvac controls down thru the center console. i'm thinking of cutting part of it out and replacing it with a flexible material to compensate so i can place the in dash there.
thoughts?
