VIP Member with OCD
Yes. They all have a gap like that even after new strut mounts are install with new struts. Nothing at all to worry about.
'09 WH G8 GT
Premium/Sport
Red/Onyx
Rotofab CAI
Cortex 93 tune
20% tint
I just wanted one.
Post Thanks / Like - 1 Thanks, 1 Likes, 0 Dislikes
VIP Member with OCD
what's that ghey silver thing on top of them? that needs to go away as it's wasted weight. (damn it need a wall smiley)
serious note one looks a little higher than the other but within reasonable. How many miles/pot holes on the struts and bushes?
manufacturing variance is pretty significant for those pieces. Key is if it's tight and no noises - don't worry about it.
If it bothers you - lift the front up all the way - and then drop it back down slowly. and it would re-settle but might not make it better. as long as it's tight and no extra noises - rock out with your spock out.
VIP Member with OCD
I bought the strut caps from Maverick Man. They aren't heavy and look better than the stock small plastic black caps so they're staying.
http://www.maverickmancarbon.com/pro...8-and-chevy-ss
I got my suspension overhauled 3 weeks ago; everything is brand new including the front strut bushings and bearings. I've driven less than 500 miles with the new suspension so it hasn't even settled yet.
Thanks for the feedback. I think the reason one looks a bit higher than the other is the difference in the angle when I took the photos. Look at the red bracket. One is almost eye level and the other one is not.
I'll show the mechs at the shop and get their take.
Napalm
I saw on the other forum that some say it looks like something is wrong with them. If you want, you can pm me your phone number and I'll text you some pics of mine that have about 3k miles on them and are PPV's with whiteline mounts and bushings. They look just like that.
'09 WH G8 GT
Premium/Sport
Red/Onyx
Rotofab CAI
Cortex 93 tune
20% tint
I just wanted one.
My poly strut bushings installed with zero gap and settled in to less than half of the gap shown in the picts and that was 6 years ago. In fact I changed out the stock bushings when the gap got to where your new bushings are. So it does look strange. Does the strut rod look off centered in the hole through the strut tower? You may want to take the top disks off to see. If they are visually centered then you are OK.
But take some gap measurements and use those as the starting point for these bushings. Hopefully the gap won't increase.
VIP Member with OCD
I'll double check but they did look centered to me. There's no play in them. Gonna bring it up with the shop that did the work next week.
WhatNext
I think your picks are accentuating the difference. Look again at the bottom of the bush (yeah boy) and notice how they don't even look the same. Meanwhile I bet they looked that way out of the package too.
You did say rubber bushes right - they deform a bit more than urethane ones in general - so they also have more material in places. SO look again and notice the bush is indeed touching on the bottom - just not flush with the mushroom top. because it's probably not flush to begin with.
THus again I wouldn't worry about it.
However as mentioned - few minutes you can take the tops off - check them for locations and if they have play (which I bet they do not) and then put the tops back on.
