Fuse 10 on the interior fuse block is the stoplamps. Maybe it's a brake light flasher module that can be disabled with the switch. Have someone stand behind the car while it's in park and press the brake pedal with the switch in each position.
Thank you guys for all the suggestions but I finally thought to look in the trunk and of course the blue wire the switch is spliced into goes all the way back into the trunk and then it just hangs and isn't connected to anything. I'm guessing maybe it's for subwoofers or something and maybe the stop lights
