Results 1 to 10 of 17
Thread: contact dealer code
    Apr 2014
    Default contact dealer code
    after having my car sitting outside the shop for 2 weeks and then grtting work done, new intake manifold, underdrive pulley, and replace rocker arm rail, and front timing cover gasket now the won't start or even try to crank over and contact dealer is popping up and stability control turning off, and fuel gauge wont read, and battery says 0% i unplugged battery overnight and charged it doesn't make a difference and it's a new battery, car has been cammed for months now
    Quote Originally Posted by antec800 View Post
    Sensor on timing cover plugged back in? On the right, near the bottom half.
    Sounds like a ground was not replaced.
    Apr 2014
    no grounds were taken off, I think the ecm went bad not sure how I can test it withiut buying a new one and paying to get it reprogramed
    Fuel gauge not reading will give you the contact dealer message. Can you hear the fuel pump fire when you turn the key to run?
    Apr 2014
    no I can't hear the fuel pump
    There's a fuse in the trunk for the fuel pump.
    Apr 2014
    checked all fuses still good the car wont even try to crank it's like the bcm or ecm won't let it
    Apr 2014
    new battery in all fuses and relays good, car still won't even try to crank fuel pumps disabled, throttle body disabled, stability and abs disabled, really stumped...
    Aug 2017
    Mine is doing the same thing, what did yours end up being? Everything keeps disabling. i unhooked battery nothing. i unplugged transmission plug right above transmission pan, plugged it back in and put battery cable back on and it fired right up drove it 7 miles and contact dealer came back up and the dash and everything went to 0. Car was still moving and running but dash was flickering, RPM/MPH bouncing all around and doors started locking and unlocking and dash was saying car was in park even tho i was going down the road. i was limited to 1st and 2nd gear. when i got home and shut it off it was back to a no start condition again with red x, trac control disabled, very low fuel (even tho i have half a tank), and no power to anything showing under engineering mode. temperature and engine oil life even say 0. The only way i can get the car to start back up is if i unhook battery, get under car, turn and unplugged transmission plug and plug it right back in, the problem is this only buys me a few mins to get the car moved and it eventually goes back to a no start condition soon as i shut it off. anyone please help!! i need to get it to dealer to see whats up but i afraid i will end up stuck on the side of the road or hurt something further. Thanks in advance for any advice.
