Results 11 to 20 of 35
Thread: P0449 and P0455
    Yep, new cap. It didn't change the behavior.
    sorry then. Good luck with the tank drop
    Before I tackle this, is it possible to relocate the thing? Should I need to do this again, I'd rather it be simple.
    Lake Jackson, Tx
    There is no need to drop the tank...this is a common misconception (similar to "the canister and valve are one piece")
    you may be able to...you'd have to lengthen the wires. Look at the 04-06 GTO valve for reference. it's in a much easier place (fender well). Not sure it's worth the effort. after replacement, mine went another 80K (till I sold it).
    Mar 2014
    Moyock, NC
    I replaced mine without dropping the tank. Dropped rear cradle which is easy and went in from wheel well. Whole process was less then an hour.
    Is dropping the tank all that hard relative to the cradle?
    Dropping the tank instructions:
    Step 1 - remove the rear cradle
    Jun 2014
    Quote Originally Posted by todds87ss View Post
    I think there is a write up with a few pictures showing how to get to this through the rear wheel well, passenger side if I remember correctly. It might be on the other G8 forum.
    However I can't say much about it, a revised gas cap from the dealer did the trick for me
    09 GT PBM - Red/Onyx - Sport, Premium, Roof
    Rotofab, LS7 MAF, Pat G, Kooks 1-7/8 Mids w/ HFC's, Magaflow Cat-Back, 3.45 gears
  9. #19
    AH
    question then - if in the area and with cradle dropped - would you not also take the time to drop the tank - and replace the fuel filter?
  10. #20
    Fuel filter is in the fuel pump. Cut a hole under the back seat.
