Results 11 to 20 of 41
Thread: I am so tired of water leaks...
    Some of the parts sites say the SS strips cross ref, so that's good. $620+ shipped for a complete set of door and body mounted weatherstrips, is not good. I suppose I could just do the left side, but then I'll have to get the right side later down the road I bet.
    Did you look at the link I posted?
    Well, I did now. Part prices are higher, but shipping is a lot lower. There is one door mounted strip that they don't have. One place I found doesn't say it's out of stock, but they want $140 to ship it.
    Well, go to your dealer with the part numbers. You won't pay freight if they ship it into their location.
    I popped the bottom interior door trim off quick last night. There were clear water trails of water going in under the trim. There was also evidence of water coming out of the bottom of the inner door panel. So I think the internal plastic sheet liner may be the issue. If I'm lucky, I'll have some time this weekend to open the doors up.
    Beyond Help tchr49's Avatar
    michigan
    Hope that solves the problem for you.
    Clear silicon will be your friend for sealing the plastic to the door, or you can find the goop to seal it as well. Hope this solves it, but I'd look into new window trim/seals as well.
    Senior Member Blown396's Avatar
    Jan 2009
    Albuquerque, NM
    Use this to re-seal your water shield to your door:
    http://m.summitracing.com/parts/tes-...Fc-Ffgod8BMLsQ
  9. Thanks J Wikoff thanked for this post
  10. #19
    ^^yep, that's the goop^^
  11. #20
    I just got done opening up the doors. The rear door liner had a large "unstuck" area right in the middle, and the front door had a few small areas. I used the goop linked above and redid the lower half of each liner. I hope that does the trick. Thanks for the tip!
  12. Likes Chewy liked this post
