Thats a great looking setup you have G8V8!
2008 Magnetic Gray Metallic G8 GT Premium - DOD Delete, Livernois stage 1C cam, 25% UD pulley, Vararam.
(SOLD) 2008 White Hot G8 GT premium - DOD Delete, COMP 269LRR HR13 cam, 3.23 Camaro diff, 25% UD pulley, Circle D Pro II 258 2B stall, SOLO High flow cats
12.612 @ 109.31, 1.886 60' ft on street tires.
RacnJsn95
+1
Another option, pick up textured ABS sheet off amazon trace the same to match the roto box without gasket. Drop a perpendicular section to will allow it to be secured with plastic rivets. Below is an example with my spectre box. I'll do the same with my roto box once I complete the 5" system. BTW, ABS easy to work with.
Sport /Premium
Thanks for the info. I was planning/hoping I could use ABS to fill any notches I have to cut into the RF SS airbox.
Tracking on the intake says it should be here tomorrow, probably won't have time to play with it until saturday or sunday though.
Well the intake showed up yesterday... After looking it over and looking at the car, I can see that this project is not for the faint of heart...
It looks like it's going to take some serious chopping to get this thing to work.
Sounds like it's not worth it IMO. I make a TON of N/A power with the original 102mm kit.
Chewy do you drag your car? I'm very curious of your ET and trap
you have a serious N/A build.
Chewy
Chewy do you drag your car? I'm very curious of your ET and trap.
I actually don't! I'm a self admitted poser! lol!
Sent from the internet using Borg technology.
Chewy
I understand. I was just curious how that block and heads performed. What cam did you install?
