Results 1 to 2 of 2
Thread: LS7 MAF Swap Pin Out Information
    Exclamation LS7 MAF Swap Pin Out Information
    Someone was looking for this and I couldn't for the life of me find it anywhere on the forum so I'm posting it here for anyone else that may need it in the future. I've also added tags to facilitate searching in the future.
    G8
    Pin - Wire - Circuit - Function
    A - 0.5 YE - 492 - MAF Sensor Signal
    B - 0.5 PK - 439 - Ignition 1 Voltage
    C - 0.5 BK - 450 - Ground
    D - 0.5 BN/RD - 472 - IAT Sensor Signal
    E - 0.5 BN/WH - 2760 - Low Reference
    LS7
    A - 0.35 YE - 492 - Mass Air Flow (MAF) Sensor Signal
    B - 0.8 BK/WH - 451 - Ground
    C - 0.5 PK - 539 - Ignition 1 Voltage
    D - 0.35 TN - 2760 - Low Reference
    E - 0.35 TN - 472 - Intake Air Temperature Sensor Signal
    Beyond Help Darkmanx's Avatar
    ft lauderdale fl
    They also sell adapaters on ebay for 20 dollars but good info
