so i had my factory alternator light come on a few months ago and decided to have it rebuilt. i took it to a local place in honolulu and had them do their thing. I put it in once they were done and all was well for a few months. Last week i was backing the car into the garage and i heard a pop and some rattling when i gave the car even a little gas. after further inspection, i narrowed it down to the alternator. i ended up taking it out and could see the springs and brushes came loose and were grinding on the rest of the internals. so i took it back to aforementioned shop as they warranty their work and they rebuilt it. i did get some power steering fluid on the alternator getting it out, but they cleaned it up. I got the alternator back the same day, installed it and took it for a ride. All was well for the first two miles, then the light came back on. monitoring the battery in engineering mode and my aeroforce gauge i could see that the battery voltage was low(11.5VDC) but remaining constant regardless of rpm. So yet again i took out the alternator and brought it back to the shop. before i yanked it though i took local readings at the battery and alternator and both returned reading consistent with the dash and gauge. So this time they swapped out the rectifier and said that it was reading fine. I put it in today and started the car. Voltage was at 13.7VDC and remained there +/- .2vdc. I shut the car off and turned it back on and observed it go to 13vdc and stay there +/- .2vdc. I have not taken readings at the alternator since i started up the car for the first time following today's install. I managed to take it over to autozone to have it tested and they said the battery was fine but the alternators voltage regulator was bad. after having it rebuilt several times im starting to think that its outside the alternator. i unplugged the harness going into it and watched the voltage go from 12vdc to 13.4vdc. the alternator light didn't come on today yet but i had the same downward trend. Does anybody have any ideas of where to look. I have started reading http://www.crazypauls.net/VEVMElectr...ingSystems.pdf but would like some input in the meantime. i need to get my car back on the road as my wife is starting to get more and more irritated as the morning drop offs go by. thanks in advance.
joe
