Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: Brake dust on one wheel
  1. #21
    Too many projects.
    Detroit, MI
    Whats your email?
    I'll send you a file tomorrow
    2009 Saab 9-3 Combi / 2.0T
  2. #22
    Well, I backed off the parking brake as much as I could and it did not affect the noise. It still comes and goes, and I can hear it at any speed. It kinda sounds like the dust shields dragging, but I didn't see any wear marks on them. The wear paths on the rotors looked the same as the front rotors. It sounds pretty ghetto. I gotta fix this but I don't know what to try next.
  3. #23
    After a 100 mile round trip on the highway earlier this week, I can't hear anything in the car. It was cold and wet today so I didn't roll the windows down to listen though. Maybe the pads and rotors were on the thicker side and just needed to wear down a bit.
    And my parking brake does nearly nothing after backing it off. Can these be adjusted like drum brakes? Good firm brake application while going backwards?
  4. #24
    Jul 2011
    Gilbert AZ
    Did u ever figure this out?
    09.1 G8 GT, 20x9/10 Red G wheels, magnaflow catback, DT's, Crawford ported TB/manifold, Spectre 4"/LS7 MAF, Rotofab, HID's, Aussie SV6 tails, GXP rear diffuser, BMR strut bushings/cradle inserts, BMR sway, Megan Coils, CTS-V 6/4pot Brembos, HSV steering wheel.
    http://i92.photobucket.com/albums/l4...psce2f18b1.jpg
  5. #25
    Yeah. If I remember right, I adjusted the parking brakes through the little rubber plug in the rotor hub. It's been fine since.
  6. #26
    Jul 2011
    Gilbert AZ
    Did u ever swap that caliper as well? Or was it the ebrake,shoe dragging the whole time causing all the dust?
  7. #27
    Jul 2011
    Gilbert AZ
    Can you send me the how to? Djerickd at gmail
  8. #28
    The original problem was simply that the inner pad was worn away. I determined the caliper was fine after fiddling with it a bit. The dragging sound after install was apparently caused by the fresh pads and rotor were just a little too thick or needed to bed in better. The sound went away after a long drive.
    If you take the wheel off, you'll see a rubber plug in the rotor hub. Pop that out and you can see the star wheel. Rotating it adjusts the parking brake. I used a small flat head screwdriver against one of the wheel teeth and tapped it with a mallet to make it spin. It took a few iterations to get it right.
