Results 1 to 2 of 2
Thread: Need advice from LY7 GURU KNOW IT ALLS PLEASE!
    Senior Member jlab1982's Avatar
    Dec 2013
    Default Need advice from LY7 GURU KNOW IT ALLS PLEASE!
    Ok.. so recently i heard of someone with a LY7 Equipped G6 swapping the heads out for the GMC acadia heads and they made more power.
    I tried getting a hold of the guy on FB but no answer from him.
    So what i have found out is that the heads from both the Acadia and V6 Camaro are direct port injection.. ours are not.. The question i have is two fold.
    1. How much of a process wold it be to swap the heads and do the necessary changes in fuel management to make them work.
    2. If i stick with my stock heads and have them ported/Polished and milled.. could i throw a V6 OEM camaro Cam in it to make the extra power? Would this work
    Thanks in advance..
    Joe
    May 2014
    Annaheim saskatchewan
    if your looking to get head work done id go order a cam that would suit the work done to the heads look up mace engineering they wont steer you wrong. im still planing out my v6 motor build
