Results 1 to 10 of 18
Thread: Tire pressure problems
    Member Code187's Avatar
    Apr 2014
    Shepherdsville,Ky
    Default Tire pressure problems
    This all started by changing out the battery. After about 200 miles tpms fault started, all 4 showing dashs, then they started reading correctly again, few more miles dashs again, relearned all sensors ok, 100 miles or so,l same thing. brought the car back home, dropped all the air out, refilled with nitrogen and performed a relearn again, seemed to work, all sensors showing correct pressure, drove it again around 100 miles it's back, but shortly started reading correctly. Any insights would be helpful.
    VIP Member MongosG8's Avatar
    Connecticut
    Having issues with my TPMS also. Installed new tires. Set my sensors and after a couple days boom my senor fault went on and no pressure showing on all 4 corners. Got out ..looked ..had air.
    Tried to inflate deflate relearn ..etc etc still the same shit.
    Was told that this is a sign of a sensor failure. How do you tell which one I asked .. You dont. So I guess I need all new sensors ..not worth the BS IMO. So I have the fault showing.
    2009 White Hot G8 GT w/ Onyx/Red Int. Sport/Premium, No Sunroof
    Borla Cat Back, VCM OTR Intake, DBA 4000 Slotted rotors and Hawk Ceramic pads, GXP Diffuser painted White, GXP Fascia, Crystal Clear side markers,
    Black Scoops, 20% Tint all around
    20" Camaro SS polished staggered, Shark Fin, Infinity 6032si
    R.I.P. Charlie (Mr GRRRR8)
    R.I.P. Chris (Panzer Leader)
    I've changed my battery after 5 years. New tires, same sensors. I'm not having that issue. It's hard to believe that all 4 sensors quit at the same time.
    Under more construction.
    Connecticut
    Exactly ..After never having an issue before and all of a sudden .. Called a different service dept ..they did say 1 fault could cause all of them not to relearn and cause the fault for all 4
  5. Thanks Code187 thanked for this post
  6. #5
    Go into Engineering mode. There it will show the tire pressures and the bad sensor will read really high. (148 psi if I remember correctly)
    p.s. Order on the tire pressure settings in Engineering mode : LF LR RF RR
    Quote Originally Posted by MongosG8 View Post
  7. Thanks 6 litre, STL_G8GT thanked for this post
    Likes 6 litre, MongosG8 liked this post
  8. #6
    TX
    I think it's like our alternators, it's just time for things to start craping out.
  9. #7
    Quote Originally Posted by JimmyJazz View Post
    Shut your mouth!
  10. #8
    Connecticut
    Quote Originally Posted by Sheffield Steve View Post
    p.s. Order on the tire pressure settings in Engineering mode : LF RF RR LR
    Thank you! I really appreciate that! ..just goes to show that dealers do not know shit about our cars!
  11. #9
    Junior Member mforest4's Avatar
    Jul 2013
    I have had two go bad one at a time, now about every 100 miles they all go blank, they may come back in 10 miles or 100, no pattern to it, resetting doesn't work when they are all dashes, I guess I will replace the remaining two and post the outcome
    06 GTO Panther Black 6 speed, Magic Stick 3, HP Tuned etc.
    08 G8 Panther Black Premium package, VIM
  12. Likes Code187, MongosG8 liked this post
  13. #10
    Jul 2011
    Tucson
    It's the battery in the sensor. They don't last forever.
    White-hot G8 GXP...1c cam, NicD tune, Kooks mids, xpipe, Solo axback
    TVS 2300 added April 2015
    12.2@116 at Tucson Dragway, DA was 4000 !!
