Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Tire pressure problems
    Member norton13's Avatar
    Jan 2013
    Toronto
    I have only 1 sensor go bad replaced it problem solved.
    Junior Member mforest4's Avatar
    Jul 2013
    Update, I took it to the stealership and they replaced one of the two I paid them to replace 15 months ago, sorry out of warranty was the story and another 125.00
    06 GTO Panther Black 6 speed, Magic Stick 3, HP Tuned etc.
    08 G8 Panther Black Premium package, VIM
    Jan 2013
    Toronto
    125.00 to replace 1 sensor.
    That is a bit expensive as the OEM ones are only $15 on ebay.
    Quote Originally Posted by norton13 View Post
    Feb 2011
    Latham NY
    I bought 4 online only to find out 2 were DOA when the installer checked them on the counter before touching my car. Ended up getting all 4 from the installer. Yes, more expensive at $50 each but that included installation and no further waste of my time.
    VIP Member Crazy8's Avatar
    Apr 2010
    North DFW
    Mine just started doing the same thing. Would have been nice if this problem came up a few months earlier so I could have had them replaced while the tires were being changed...
    09.5 LR G8 GXP A6
    For mods list, honk 3 times.
    Is the order of representation in Engineering Mode always the say - regardless of getting the system recalibrated for the display.
    Because if that's the case it sure would help me out.
    I have one that dead to - system fault all the time. in engineering mode it shows as the items reporting 148, the others are about correct.
    VIP Member MongosG8's Avatar
    Connecticut
    From what I was told they stay in the same order Like Steve mentioned LF RF RR LR
    My G8 in Eng mode states 148 across the board even though I know its only the RF that is bad. When I go to manually re-calibrate it will beep for the LF RR & LR only the RF doesn't and its the one I know is bad.
    From what I was told from the dealer ..if one sensor is bad it usually shows them all as 148 (bad) and will not re-calibrate until the bad sensor is replaced. Basically saying you must pay us to replace all 4 now for almost 300 bucks. I will live with it
    2009 White Hot G8 GT w/ Onyx/Red Int. Sport/Premium, No Sunroof
    Borla Cat Back, VCM OTR Intake, DBA 4000 Slotted rotors and Hawk Ceramic pads, GXP Diffuser painted White, GXP Fascia, Crystal Clear side markers,
    Black Scoops, 20% Tint all around
    20" Camaro SS polished staggered, Shark Fin, Infinity 6032si
    R.I.P. Charlie (Mr GRRRR8)
    R.I.P. Chris (Panzer Leader)
