Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: My mod list for my V6 G8
    May 2014
    Annaheim saskatchewan
    Default My mod list for my V6 G8
    here is a complete list of what i am going to do for performance mods majority will be purchased through ADMgarage.com and are listed in cost of mod kinda
    1.vietneess throttle controller
    2. 25mm manifold insulators
    3. camaro long tube headers/full exhaust
    4. tune
    5.otr oressome cold air intake
    6.3.27 lsd differential
    7.CPR6 intake manifold
    8.210/210 mace cams
    probably be a while before its all done and may out in some supporting mods for the cams if deemed necessary. going to build this car instead of buying a GT. wish me luck. if there is anything else i decide to put on i will add to this thread and post results and install videos
  2. Likes Chewy liked this post
  3. #2
    Sep 2015
    That's a man with a plan, and deep pockets! Can't wait to see the result. Good luck and keep us updated!
  4. #3
    Senior Member wastedrubber's Avatar
    Mar 2012
    Metro Detroit
    What kind of power would this put you at and what cost compared to selling your V6 and getting a GT? Not trying to dissuade you, just curious.
  5. #4
    May 2014
    Quote Originally Posted by wastedrubber View Post
    i just wanted to be different everyone is building the V8 to be fast so i decided to build the V6 instead plus car is paid off so wouldn't make sense to trade in. AS for how much power ill end up pumping out fully built im estimating adding about 100rwhp so should be around 350-400 range plus whatever i can get from the tune also.
  6. #5
    May 2014
    https://www.youtube.com/watch?v=GYwv0Tl4FAc intstalled the throttle controller
  7. #6
    May 2014
    little pull video i took this weekend
    https://www.youtube.com/watch?v=vliR388VCv8
  8. #7
    Member WhiteBeastG8's Avatar
    Houston,Texas
    I gave up putting money into G8 V6 , so I ended up buying a 2016 Ford Mustang GT Premium . I still got my G8 though can't let her go .
    08 Pontiac G8 V6 Comfort and Sound Package :
    20 x 9 Borghini Wheels
    Tinted
    Roto-Fab intake
    1 inch Drop on Eibach
    Debadged W/ White Arrow Heads
    GXP Diffuser
    Pypes Axle Backs
  9. #8
    merca!!!
    Go all out and build the engine to turn 10k with boost!
    I remember an article I read about a camaro v6. The engine came out and was destroked with light rotating assembly. Tons of head work, cams, and the rest of the good stuff. Twin turbo. The car make something like 550 whp. Then transmission problems. The follow up article was on line with a T56 swap some how.
    I thought it was cool to see someone put that effort into the v6. And the cost was about the same as if he built the v8. A few hundred HP short of course. But the v6 saved weight and was a smooth power band.
    2008 GT-M. PBM, #885
  10. #9
    Jay Leno had an original Gen5 with a TT V6 back in like 2010 I believe. Was built with help from GM (of course) if memory serves.
  11. #10
    May 2014
    https://www.youtube.com/watch?v=SzZqoyWQfEE pull with the long tube headers
