I'm going to be doing the front brakes on the G8 this weekend (DBA rotors with Hawk HPS pads). This will not be my first brake job, but I want it to be my best. I have a dial indicator to check the rotors for run out, blue locktite, and lube. Can anyone give me the torque numbers for the caliper and caliper bracket bolts? I plan to clean and reuse the stock bolts with a dab of locktite. Am I forgetting anything or anyone have any tips? Thanks
Are you bleeding the brakes? These cars are old enough now that they should be bled.
Make sure you bed the brakes in per the recommendations. I loved my HPS pads. They dust some, but I loved the feel of them.
Not sure if I'm going to bleed them now or not. I'm only at 25k miles, but the car is almost 7 years old. I'll do it sooner or later, maybe when I do the rear brakes.
I will be beding them pure the instructions.
The fluid is Hydrophilic (absorbs moisture) which is BAD! Age is more a concern than miles!
I'm going to do mine on my GXP and at the same time since I'm bleeding them, I'm doing SS lines.
I m doing the same thing this week ..DBA 4000 Slotted with HPS pads on all 4 corners. Highly recommend bleeding the brakes. I purchased SS lines purposely so I have no choice ..lol!
As for torque specs if your going to reuse the caliper bracket bolts I read people torquing them to 80-85 ft lbs. I seen this on a thread a few years ago.
Just get the Valvoline Syn DOT 3/4 at the local auto parts store. See image!
It's rated at a higher boiling point that the OE stuff. I used it exclusively for years in my motorcycles and it worked great!
