Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 58
Thread: Seat Brackets
  1. #21
    Beyond Help gr8lover's Avatar
    SE Michigan
    WHat are your plans for the seat belt mounts/seat belts?... interested
  2. #22
    How the end user chooses to handle the seat belt depends on the seat they purchase and their preference. For the one I use in my car the buckle was removed from the stock seat and attached to the race seat at an existing mounting bolt. The other end of the belt was attached to the seat mount bolt. Alternatively, additional holes could be drilled in the brackets for attachment points for the buckle and belt. If someone has a cage or bar then the belt could be attached to those.
  3. #23
    Default Test Fit
    Test fit went well. Just a tiny bit of grinding needed on the tabs for them to fit. I wanted them tight. Fit is the same on driver and passenger side. My drill press self destructed yesterday, so I need to buy a different one this week to finish drilling holes for the back tabs.
  4. #24
    Feb 2015
    Toronto
    Thanks for the update rough luck with the drill!
    Little Lunati. Kooks long tubes into Solo Mach cat-back Roto-fab CAI
    FE3 Struts/Shocks Eibach springs Whiteline bushings and anti-roll bar
    Rick Crawford tune
    Wheelwell
  5. #25
    Feb 2009
    Hope Mills, NC
    You don't even have to weld mine, that is the easy part.....I can TIG them up pretty quick.
  6. #26
    Boardman, Ohio
    http://airbagsystems.com/simulator.html
    Might be able to turn airbag warning lights off.
  7. #27
    Parts for 3 sets going to Rick tomorrow since he can weld his own. The rest coming soon.
  8. #28
    Feb 2009
    Hope Mills, NC
    Sweet!
  9. #29
    I got the rest of the parts deburred today so you will not cut your finger on them. They will be going to the welder the next day or two.
  10. Thanks fengstang thanked for this post
    Likes JonnyG2132 liked this post
  11. #30
    Default Lookie Here
    OK, they are ready to go other than the test fitting. I should be able to test fit them this weekend. Final price is $120 for a set of 4 brackets shipped. Believe me, that price is a bargain and if I do another run they will be more expensive. I will PM my Paypal ID to everyone that signed up for a set.
