Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 58
Thread: Seat Brackets
    Feb 2009
    Hope Mills, NC
    I'll jump on a few sets to help out...
    Apr 2013
    In for a set
    2009 GT LR
    404 Stroker RCR Top End Big Lunati on 112 Coan 3600 Stall - No times yet
    RCR Top End Big Lunati Coan 3000 (flash 2400) - 11.76 @ 120 60' - 1.75
    Lunati 231/239 on 111 11.35 @ 123 60' - 1.67 in 3000' DA
    PTC 3800 Stall - ??
    BMR bits in the rear Eiback springs all around 3.45's
    OK, here is what we have so far:
    1. wickedg8gt - full set
    2. Dctg8 - full set
    3. The Adam V - full set
    4. JohnnyG2132 - full set
    5. fengstang - full set
    6. G8-4-Speed - X full sets
    7. Stevesm943 - full set
    8. Nate - full set
    So we are sitting at 8 or more sets now. If you want some, post here by June 7th.
    Feb 2015
    Toronto
    I'm in for a set of drivers and passengers too please TMH
    Little Lunati. Kooks long tubes into Solo Mach cat-back Roto-fab CAI
    FE3 Struts/Shocks Eibach springs Whiteline bushings and anti-roll bar
    Rick Crawford tune
    Wheelwell
    I have ordered parts for these. I will let the interested parties the final price once they are welded together. After that you can paypal the money and I will ship out after I tweak and test fit each set. I will update this thread once I get more info on timing.
    Oct 2009
    Webster, NY
    Thanks
    2008 NA G8 GT
    1/4 mile = 10.93 @ 123
    60' = 1.47
    DA = 500
    Nov 2010
    Louisville, Ky
    Thanks. Appreciate it.
    An update. Most of the pieces arrived over a week ago. Still waiting on the laser cut tabs. They originally said they would be done last week, but they were not. They are working on them since they contacted me to clarify dimensions. The tabs should be done this week sometime. This order is small potatos for them. Then I can put a test set together to verify and adjust the fit. After that they can all be sent for welding. Still looking at a couple weeks before they are ready.
  9. #19
    Oct 2009
    Webster, NY
    Thanks for the update. No worries. Take your time
    2008 NA G8 GT
    60' = 1.47
    DA = 500
  10. #20
    Default Got these in
    Now that I have these I can test fit a set. I hope to get some drilling and bending of other parts done this weekend.
