I will need to get tires and install them on my new wheels soon. What's the shop? In Rincon?
Savannah Tire in Pooler. Not sure if you will be able to get that pricing, but it's worth a try. I basically posted the quote on the local Savannah car FB page and let the shops battle it out.
Nice.... Right in my area. Good to know.
The Nitto 555's are great tires but expect only about 25k miles. I had them on my GTO.
94GT
Yea, I've run them before. I view the life of these tires as high due to my normal tire being a NT05, NT05R or Micky ET Street.
I agree that Nitto is a good tire with great tread design and good grip though they seem to wear quickly.
Okay, so the car has now been lowered and aligned with the bent wheel straightened (was out 200+ microns in one location, 140 in another and 100 in another, all of which have been brought down to <85 microns). Everything was brought in to spec (see photo below) for the alignment, however, the car still pulls hard to the right. It did so after my first alignment after the new tires and now again after the install of my lowering springs. The tech said it had to be tires. I even cross rotated the front two and it's still pulling to the right. Guess I'll be contacting Discount Tire Direct to see about some sort of warranty. Do y'all agree on tires?
I have the same problem, pulls to the right and the inside edge of my front tires wear out very fast. Just put new tires on and stabilitrak + abs lights come on after driving the car a block or so.
If discount tire is of no help and your tires are not directional, rotate them on the wheels so the inside edges are outside. May help if they are unevenly worn
If you swapped the fronts and they are still pulling to the right, it's not pointing to tires cause if it was the tires, it would then pull to the left. I recall you are staggered but put the rears on the front of the car and just to see what happens.
Hope the vibe is gone now that you straightened that wheel.(saw your other post)
This was my exact thought, and of coarse this was the only time I didn't watch the guys swap the tires. I came up on them as they were balancing one and mounting the other. I wouldn't put it pass them to have put the same tire back on the same rim.
I thought the vibration had dissipated, but unfortunately it seems to have come back at a lower speed...
