Probably my eyes playing tricks, but check those tire sizes.
The 2 on the inside look different from each other.
Wow, yes they do.
I checked one 255 and one 275, but not all four.
Just ordered the following:
1 x BMR Bushing Kit, Rear Cradle, Polyurethane, Street Version - 2008-2009 Pontiac G8 GT & GXP $169.95
1 x Eibach Pro-Kit Lowering Spings - 2008-2009 Pontiac G8 GT $268.95
1 x Whiteline Plus Strut Mount Bushings and Bearings - 2004-2006 Pontiac GTO & 2008-2009 Pontiac G8 $164.95
1 x ACDelco 506-883 GM Original Equipment Front Driver Side Suspension Strut Assembly $76.02 + tax
1 x ACDelco 506-882 GM Original Equipment Front Passenger Side Suspension Strut Assembly $71.53 + tax
2 x ACDelco 560-726 GM Original Equipment Rear Shock Absorber $122.32 + tax
Plus the $650 for the tires.
Hell....I should have just bought a modded lower mileage G8
Any suggestion? I'm about to have my girl bring the tires from home in the Yukon(30 min drive one way) so I can have them mounted, balanced and everything aligned, but I'd like to be able to know that I don't need new parts that I won't be able to get locally. I've checked local stores and no one stocks G8 tie rod ends, and I'd certainly need to replace them(if that is the cause of the play/noise) before an alignment.
It was tricks. Sizes are as ordered.
If it were the LCAs, there is a test that specifically shows the ball joint slop. It doing the 3 and 9 shake but watching the ball joints from under the engine. Otherwise, best guess is the tie rods. 12 and 6 should also show ball joint slop.
We had three mechanic under the car yesterday replicating the 3 to 9 test. Nothing was found. The car didn't even make the noise that you hear in the video. 12 and 6 are good and tight, no slop. All components were visually and touch inspected, and everything seemed to be good.
I was planning to install these parts myself with some help from a fellow G8 owner who has already performed this install, but I was quoted at 300 dollars for everything installed and done by the shop that performed my alignment/balance. What do you guys think? Bite the bullet and save the headache by dropping 300 to have it done for me, or should we be able to knock this out without any crazy issues to face?
That seems like a great deal Garrett. Not sure what the shop hourly rate is, but typically at $100/hr is only 3 hours, which sounds like a great deal to get it done without having to wait for helpers.
Jeff
Yea, the shop is really hooking me up to insure I become a return customer. I got the original quote to mount, F.R. balance, align, etc. down from 225 to 100 bucks.
