The entire bracket and bolt are gone theres just a hole there in the morning ill look for that ground in the area its possible i pinched it down somewhere when i reinstalled my cai
Sent from my iPhone using Tapatalk
Erbby325
Maybe the bracket and the whole thing are stuck down somewhere, that ground comes from just above the driver headlight, running along near the hood release cable.
I'm going to bet that the lack of ground is your problem.
Bracket or no bracket, find the ground wire and connect it to one of those shiny bolts to complete the ground. Then start the car and you'll know if it is the source of the problems.
Like stl-g8gt said, it's likely the cause.
Its fixed! thanks guys it was under my air intake inlet must of accidentally pushedbit down there when i reinstalled it now everything works great
Post Thanks / Like - 1 Thanks, 1 Likes, 0 Dislikes
This totally helped me fix my weird issue with lights and remote start. Thank you SO much.
